JMB RetrofitsVolks Autos
    Aug 2013
    27
    crankshaft sensor location help
    just about to change the crankshaft sensor and cant seem to find it.
    audi a3 2006 s line 170.
    if anyone can tell me where it is or an image of the location would be a massive help .
    thanks all
    Jan 2011
    northants
    165
    its located behind the oil filter/cooler housing
    between the engine and gearbox joint about 40mm up from the front casing bolt
    you need to remove the oil filter housing assy to gain access
    you will need a ball end 5mm allen key
  1. Where is the Crankshaft position sensor located?
    By ~RS~ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2010, 21:59
  2. 3.0 v6 temp sender sensor location help.
    By drewbee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2010, 13:27
  3. Engine Speed Sensor Intermittent ...... HELP
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2007, 23:31
  4. A6 Parking Sensors-please help
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th June 2006, 18:54
  5. Steer Angle sensor, location
    By MONKIEE in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2006, 18:06
