Results 1 to 11 of 11
    Apr 2013
    Chipping Norton
    50
    2.0 TDI WON'T START
    Hi, just accidentally started car after sitting 2 weeks in gear and now it wont turn over. Doesn't sound like a battery problem or any faults on dash just wont turn over at all. Cars a 2006 2.0 TDI S Line A3
    Any Ideas as need to get it going asap?
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by lewis1 View Post
    Sounds a bit like one of the following: bad battery,loose battery connections,blown fuses,broken earth strap/loose,seized /faulty starter motor ,faulty relay and blown fuse.
    i would jump start first off and then get a multimeter and a mallet for the starter
    Apr 2013
    Chipping Norton
    50
    Its not electrical as left for about 20mins and nearly turned over and fired, then tried again after and sounded like no hope again
    Apr 2013
    Aberdeenshire
    595
    Sounds like the battery or dodgy motor or both to me .
    Apr 2013
    Chipping Norton
    50
    Hmm...it started fine 2 weeks ago just come back from uni, but just sounds as a fuel or air problem maybe?
    Apr 2013
    Aberdeenshire
    595
    If it was turning over constantly but not starting possibly but if it's not turning over I would start with what makes it turn over and as a jump start is an easy way to rule out the battery.
    start with the basics to rule them out
    Apr 2013
    Chipping Norton
    50
    Yeh it is turning over constantly just not firing up have a feeling the start in gear did it? want to know if there are any dos or donts as need to get it started tonight!
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    Get the battery 'drop tested' my guess is it needs changing
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Apr 2013
    Chipping Norton
    50
    Battery is fine
    Boon's Avatar
    Sep 2012
    South East Kent
    428
    You've had it tested?
    Get someone to check the cranking speed with VCDS by unplugging the main loom into the engine, it will struggle to start if less than 280rpm iirc - that would still lead back to battery, starter motor battery leads....
    Apr 2013
    Chipping Norton
    50
    Sorted now, wasn't battery something with fuel problem, was painful but got it firing...lots of smoke involved
  1. Audi A3 2.0 TDI won't start
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th April 2014, 13:11
  2. Allroad 2.5 V6 TDI - Won't start after Fuel Filter change?
    By Magkakahalo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th February 2013, 16:53
  3. 1.9 tdi Q sport won.t start!
    By TTQ-A4Q in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th March 2009, 12:28
  4. Replies: 1
    Last Post: 15th February 2009, 19:59
  5. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
