Chris NottJMB Retrofits
Results 1 to 24 of 24
Like Tree2Likes
  • 1 Post By veeeight
  • 1 Post By S3Alex
Thread: S3 4WD/Traction issue
    Aug 2013
    Aberdeen
    6
    Good Morning
    I recently upgraded my clutch for my 2010 S3 Sportback to a Sachs with DMF, as the standard clutch was slipping after upgrading to REVO Stage1. Everything seemed to be going fine with the new clutch but last couple days, when putting the power down in 2nd and 3rd coming off the roundabouts on my way home from work, the car struggles to get traction and the ESP symbol flashes up obviously.
    Has anyone had any similar issues to this ? Ever since upgrading to Stage 1 it seems to be problem after problem!
    Ta
    Audi S3 Sportback - Sprint Blue - REVO Stage 1 - BBS CK - Milltek Non-Res Catback
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by Kinger View Post
    Good Morning
    Ta
    I don't think you should be surprised by this,as you've increased the power and torque,and what's happening is that the torque is overcoming grip when accelerating and cornering.
    The S3's front diff isn't great at getting power down on difficult surfaces or on cornering.
    There are a good number of things you can do to get around this,but it depends on what else you've done to the car....
    The solutions are:
    Better tyres(not knowing what you have at the moment)
    Improving the suspension with uprated ARBs and coilovers
    You shouldn't need to uprate the Haldex controller with the sort of power/torque you currently have,but changing to an ATB diff such as the Quaife would definitely gain you a lot more front end traction,but it is a very costly option.
    I'd look at the tyres and suspension first.
    Aug 2013
    Aberdeen
    6
    Thanks for the quick reply;
    I am aware of the power gains but thought maybe the 4WD could have coped with the stage 1 a bit more comfortably.
    I am running Michelin Pilot Sports so don't think the tyres are an issue, but I have looked into ARB's.
    Is there any common faults at all with power distribution ?
    Jul 2012
    Cheshire/N Staffs
    1,251
    If your ESP light flashes, Traction Control activates, the Haldex dis-engages the rear wheels, effectively switching back into FWD.
    Try the same roundabouts again, but this time switch ESP off (at your own risk) - this will help you determine if the full 4WD system is working correctly, as TC won't cut in, and the Haldex remains engaged.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
    Aug 2013
    Aberdeen
    6
    Quote Originally Posted by veeeight View Post
    Thanks for that, I will give it a go!
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    As veeeight said. I'm assuming with the weather we've had it was wet on the round about (pissed it down all week where I live)? In which case I'm not surprised the TC kicked in. I don't have mine on most of the time.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    OK....as you say,those are decent tyres,and have worked well on my car,with considerably more load placed on them,so I'd be happy with those.
    As others have already said,the Haldex system isn't quite like a lot of other 4WD systems,and may be described best as part time.
    Disabling TC is one way around it,but as veeight says,at your own risk,and a bit of money spent on the suspension will certainly aid traction.
    The system itself works well enough,but you have to look deeper to see the shortcomings....the stock suspension is a bit soft,and geared to understeer quite strongly,and the front diff is a simple open diff,that will not bias torque to the wheel with the best grip.
    This,coupled with TC that disables the Haldex when it is triggered,is a recipe for losing traction under cornering etc.
    My own car is a good example of one which really does need decent traction and suspension control,but some of the solutions to a relatively heavy car,with a pronounced understeer,and so on are not exactly cheap.
    Faults though,are pretty uncommon.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    umm interesting.. I'm trying to get my heads around this.....
    So if, a or both front wheels lose grip will the TC disengage power, or will the Haldex kick in to power rear wheels and then only disengage power if all wheels keep slipping? At what speed / wheel slip does haldex kick in?
    With ESP switched off, what dangers are there?
    Does ESP switch on again at a pre-set speed?
    turbonutz's Avatar
    Jul 2013
    Glasgow
    398
    yeh this seems interesting, so alex is what your telling us that haldex traction control is near useless if front wheels lose traction?
    Pre-facelift Sprint blue Audi S3 8P with Shark Stage 3, H&R Anti roll bars, BCS Sport turboback, ITG air intake , Autotech HPFP internals, Titanium Powdercoated OEM wheels LED interior Pack LED bulbs:
    Soon to be added AP X coilovers Porsche 996 Brembo brakes with Brembo X-drilled disks (Still!!)
    On hunt for engine mounts and O.Z Superturismo LMs(Maybe)
    Feb 2013
    Grimsby
    1,084
    i thought when the TC light flashes, the quattro has kicked in, to help with grip?
    so when does quattro activate when using TC on?
    jj.
    05, A3 8P 2.0TFSI Quattro
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    The Haldex is an electro-hydraulic clutch that allows torque to be sent to the rear wheels under certain conditions,such as under acceleration but it is also over-ruled by certain things such as the TC and speeds above 100mph as far as I can remember.
    It's a very useful addition to the car but should not be seen as something like a full time 4WD system.
    Devices like the Haldex sport controller allow torque to be shifted quicker and more aggressively to the rear but will not permit more than a 50% rear torque bias.
    So it's good but it has drawbacks.
    ESP can only be partially disabled in that you cannot switch off the ABS.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    As far as I can tell, ESP doesn't turn back on at any speed, until you've either pushed the button again or turned the engine off. Dangers with the ESP switched off is that there won't be any traction control. So 4wheel drifting will likely happen if the roads wide enough for the under steering to have happened. Other than that you won't have any power loss
    Jul 2012
    Cheshire/N Staffs
    1,251
    Guys - Don't confuse ESP - which is primarily a safety stability control (Electronic Stability Program) - with Traction and Grip.
    The intention/purpose of ESP is not necessarily to give you max amount of traction or grip (two different things), but to ensure that the car remains stable, and still with the ability to control the direction in which you want to go, under most circumstances.
    So if you overcook a corner, or lift off abruptly at high speed round a bend, or want to accelerate away on different surfaces wth different mu values and maintain steering input control, or have to do an emergency avoidance or lane change (see videos below), ESP will save your bacon.
    However, in keeping the car stable in these extreme situations, it will sacrifice certain other things, like outright power (eg; it will retard ignition, electronically close or limit the throttle) to limit wheelspin, and also disengage the Haldex Clutches so 4WD is lost. It will also brake individual wheels to get the car back on the intended course.
    The Haldex is also disengaged when you brake, and when ABS is activated, and when you yank on the handbrake (very useful for getting the rear around in the snow)
    The electronic diff (front) (EDL) will remain active up to a certain speed on the 8P's, even when ESP is disabled. After that speed EDL is not available (I can't remember what speed it is off the top of my head). But if you switch ESP off, it will remain off until you switch it back on, or reset ignition. However, as said previously, Disabling ESP will not disable ABS, nor EDL, nor EBD.
    edit: Found it. EDL remains active in Quattro cars up to approx 50mph, and in FWD cars up to approx 25mph.
    some ESC demonstration videos:
    Fifth gear - Seat Leon - YouTube
    Volkswagen's Electronic Stability Program ESP Revealed - YouTube
    Fifth Gear ABS, TC, ESP Full version - YouTube
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    From what I can remember,and what I've seen of mine,EDL on our cars is not an electronic diff as such.
    When wheelspin occurs,the car simply applies the brake to the spinning wheel,thus limiting wheelspin rather than having a proper diff lock,or LSD.
    The diff itself is a simple open type.
    Jul 2012
    Cheshire/N Staffs
    1,251
    Agreed Alex, it's just a simple braking of the excessively spinning wheel. Useful in snow, but not really for performance driving purposes.
    eg: In a snowy car park, if one front wheel and one back wheel spins, you go nowhere (no cross-axle diff locks). But with EDL stopping one or more of the spinning wheels, you've got a good chance of moving.
    It's just using the ABS electronics to simulate a LSD, with limited results.
    Nothing like the Quaife monster that you have
    S3Alex likes this.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Funny you should say pulling the handbrake up will disengage the haldex because in my s3 (when it was snowing of course) I pulled the handbrake up to get the back end out and it stalled the car. Tried it 4times. I came to the conclusion that it was because it was stopping my back wheels thus stopping the engine. Admittedly I didn't engage the clutch whilst pulling the handbrake which could of caused it but of what your saying is true I wonder what's happening to mine then...
    Jul 2012
    Cheshire/N Staffs
    1,251
    Did you give it enough right foot at the same time as pulling on the handbrake to overcome the stall?
    Either that, or you have a faulty handbrake switch/signal.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    It's kind of a shame that Audi produce cars like the S3/RS3/TTRS,and don't go that little bit further.
    I mean,if Ford can fit Quaife diffs,surely Audi could as well.
    That thing though is worth every penny so far.....it gets the power down,doesn't snatch like earlier Quaife ATBs and just does the job.
    Jun 2013
    104
    i have always have esp off its rubbish!
    Aug 2006
    NI
    785
    I find it odd that even on budget tyres and 300bhp I cant really break traction when flooring the S3 even in the wet. In a FWD car the TCS would be going mad but no bother just digs in and goes.
    so it must be bringing the rears in to increase grip but this doesnt flash the esp light. Must be only when the 4 wheels cant cut it that esp kicks in and flashes the light.
    back to boost, oh how I missed thee....
    Jul 2012
    Cheshire/N Staffs
    1,251
    To be pedantic, it's only when the intended direction of travel (detected by steering angle sensor) and the actual vector of travel (detected by yaw sensor) is different by a certain amount, the stability program kicks in.
    And yes, the rears will drive up to the point above.
    it is possible to drive fast and tight within the confines of the stability program, but that takes feel and skill.
    Much easier to be flamboyant (but not tidier nor faster) around corners, until you run out of road.
    At the end of the day, ESP or no ESP, you cannot overcome grip and physics. One will let you use the run-off (if any) and the other will keep you in lane.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,166
    Quote Originally Posted by pablo View Post
    I have to concur, apart from the budget tyres bit, my S3 has rarely lost traction.
    8P2 S3
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,308
    Quote Originally Posted by Staz View Post
    Likewise,I think traction is generally pretty good,and even mine doesn't do badly.
    Aug 2006
    NI
    785
    temp measure while my wheels are being refurbed! Trust me!
  1. wonder if any of you S3 folk know>> link to RS3 thread (traction issue)
    By jonnyfeng in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2013, 19:13
  2. S3 traction control issues
    By brasiliangringo in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2012, 23:09
  3. Vagcom Bristol to Plymouth / ABS Traction Control Issue
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2012, 11:26
  4. Possible traction control issue?
    By stevewushu in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st December 2011, 20:03
  5. 2.5 v6 TDI 163 multi - temperature sensor traction control issue
    By xooo.co.uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2010, 07:24
