Chris NottMonster Motorsport
Results 1 to 9 of 9
    Feb 2013
    Cornwall
    81
    wipers miss spot after windscreen changed :(
    basically i had my windscreen replaced, ever since that my wipers will miss a spot.
    This annoying this is that its right in my eye line, but if i have the wipers on constant it will only do it like every 1 in 5 wipes. Which i cant understand as if it was the wiperblades it would do it all the time.
    anyone got any ideas?
    thanks
    Eftwyrd's Avatar
    May 2012
    42
    I had this. Changed wipers job done
    _Zerocool_'s Avatar
    Jan 2013
    217
    I had the same. Changed the wipers fixed this for me too.
    Apr 2013
    Aberdeenshire
    590
    Could be the spines on the arms or shaft are damaged and move around .
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    Wipers have worn to the old glass, as above new wipers needed.
    Growing old is mandatory, growing up is optional
    Feb 2013
    Grimsby
    1,085
    mine does this! right in the middle of the drivers wiper. leave a big blob of water! annoying. guess il buy a new set after reading this...
    JJ
    05, A3 8P 2.0TFSI Quattro
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Ditto...
    Quote Originally Posted by LEE69 View Post
    Feb 2013
    Cornwall
    81
    Cheers guys, I'll give that a go!
  1. Wipers missing a patch on windscreen
    By audi58 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th December 2011, 00:34
  2. Knocking felt through pedals after Camblet Change..
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2007, 15:50
  3. Performance loss after Coil change... Or my imagination
    By mordz in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2007, 19:11
  4. Rough idle after cambelt change
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2005, 18:19
  5. 80 TDi "dead spot" on gear change
    By imported_JJlehto in forum Diesel forum
    Last Post: 11th August 2004, 11:52
