Chris NottSky Insurance
Results 1 to 8 of 8
Thread: How much oil?
    Feb 2013
    Cornwall
    81
    How much oil?
    this has probably been discussed a number of times but i cant seem to find it anyway.
    Servicing my A3 2.0tdi 170bhp at the weekend, does anyone know how much oil they take?
    thanks
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    typically 4.5 litres if filter changed... best pour in 4 litres, check dip stick and add more as required.
    Jul 2013
    311
    yeah 4.5 when changing the filter and near as dam it 5ltrs if you put a new sump on
    Apr 2013
    London
    135
    Yes as others have said, 4.5 after filter change
    Feb 2013
    Cornwall
    81
    Okay thanks guys
    Mar 2011
    Cleveland
    991
    Put 4 litres in, run engine at tickover for half a minute or so while checking for leaks, switch off, let the oil settle while you have a cup of tea, then check and top up as necessary.
    Textbook!
    Feb 2013
    Cornwall
    81
    Ideal, I'm doing fuel filter aswell but apparently there's a choice of 3
    Jul 2013
    311
    Get it from tps or a dealer give them reg they should be able to work out what it needs to be
  1. How much oil do i need
    By taztam in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2011, 19:41
  2. How much oil do you go through?
    By Kingston in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2009, 09:40
  3. How much oil!!
    By consilio in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st August 2008, 19:08
  4. How Much Oil to top up? (2.0 TDI)
    By giblets46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st May 2008, 13:14
  5. How Much Oil does the 2.0T Take?
    By Leetaylor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2007, 21:43
