Results 1 to 7 of 7
Like Tree4Likes
  • 2 Post By Cozza McA
  • 1 Post By Cozza McA
  • 1 Post By Cruiser89
Thread: DAB Fitting Guide...
    Crunching The Gears
    Apr 2012
    Invergordon Scotland
    407
    Hi Everyone
    After buying an AutoDab system for my car from the great guys at www.advanced-incar.co.uk , I though I would do a little fitting guide to help anyone that's planning doing it. Also show that its not that hard
    Tools
    *flat head screw driver
    *8mm socket bit.
    Time taken under 60mins at my pace, so anyone else maybe 90 mins :P
    1. So first up was to remove the stereo by putting in the four removal keys, and pulling the two opposite corners.
    2.Once out you should have it like this so you can see the connectors, just disconnect all of them and take out completely. This bit comes back in later on.
    3. I then mounted the Ariel on the passenger side of the window, but first was to remove the A pillar
    by pulling down on the inner seal like this.
    Then pull most off down the A pillar.
    4. Now to pull out the first retaining clip.
    Then once out like this pull up towards the roof and rear of the car.
    5.Then mount the Ariel so that the copper part is in contact with the A pillar metal, as per instructions.
    6. The next step was to remove the glovebox so that the cable can be run back to the AutoDab box.
    Removing this cover to get access to the 8mm bolt. There are 6 in total.
    Three at the top once you open the glove box.
    Then two at the bottom on either side
    Then the glove box should just drop down.
    7. Then run the cable down the A pillar so it comes to the bottom of the where the glove box used to be
    Then pull round behind the metal plate bit.
    8. You should have a fair amount of cable left between here and the centre console.
    Once running through the centre part to the under trim on the drivers side.
    9. For this you have to remove the bottom trim part pretty similar to the passenger side, except the whole trim doesn't need to be remove just one bolt so that the top can be pulled down.
    I mounted the box between the centre column and the steering wheel, there is a gap between the clocks and the vent if you push it up far enough.
    I wrapped it in some foam so it was a snug fit and no rattles.
    10. Connect up all the adapters as per the instructions then push then down the small gap behind the Head unit.
    Then remove the keys and push back into the dash.
    11. Then follow the set up procedure and enjoy.
    Hope this gives you confidence to try it yourself.
    Ps Give the guys at Advanced in car technologies a shout if you are after this...
    Cheers Corey
    fangio and miked79 like this.
    Mods so far...
    LED Interior Lights, Front splitter, Cruise Control.
    Puddle/ Footwell Lights, LED number plate and side lights.
    75% Window Tints, MY11 Lights, Black Optics Grill.
    MFSW, Leather trimmed Grab Handles. CH/LH Lights
    JL Audio, DAB radio
    Vinyl wrap wing mirrors
    Cruiser89's Avatar
    Advanced In Car Technologies
    Bournemouth, Dorset
    1,426
    Follow Cruiser89 On Twitter Add Cruiser89 on Facebook Visit Cruiser89's Youtube Channel Visit Cruiser89's Instagram Channel
    Great write up dude!!
    Glad you're enjoying the DAB :D
    Tim - Project & Marketing Manager of Advanced In-Car Technologies LTD. An Audi Approved OEM / Retrofit Specialist Company. All views expressed are my own and bear no reflection on Advanced In Car Tech.
    Audi A3 For Sale: 2011 Audi A3 1.8TFSI Black Edition. Low Mileage. Great Condition. Manuf Warranty
    http://www.audi-sport.net/vb/sale-wanted-audi-cars/219560-sale-2011-audi-a3-1-8tfsi-black-edition-low-mileage-great-condition-manuf-warranty.html
    Crunching The Gears
    Apr 2012
    407
    Cheers Tim hopefully a few more people will get AutoDab now.
    Then I'll rolling in the commission that ill be getting haha
    Too many channels to choose from now...
    Sandra likes this.
    Mods so far...
    JL Audio, DAB radio
    Jul 2013
    london
    29
    Great write up, always wanted DAB, not sure how I feel about the ariel on the windscreen though. Is that the only place you can put it?
    Crunching The Gears
    Apr 2012
    407
    Quote Originally Posted by rocketpaul View Post
    Thanks mate, you should defo get it.
    total worth every penny, I see what u mean with the ariel but that is the only place to put it. But to be honest when I'm driving along it doesn't bother me as I don't look out the passenger side of the windscreen.
    Mods so far...
    JL Audio, DAB radio
    Cruiser89's Avatar
    Bournemouth, Dorset
    1,426
    I have the same system on my car and I don't even see it anymore.
    It's been in my car since Feb and my girlfriend hasn't even noticed it ye. ha
    miked79 likes this.
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    751
    Great write up m8
    Audi A4 BE 2.0 TDI 177 Quattro
  1. Armrest fitting guide?
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2011, 07:02
  2. Suspension Fitting Guide / Diagram
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th April 2009, 18:27
  3. Induction Kit fitting guide
    By mattv6 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th November 2008, 20:20
  4. Need a fitting guide for PSS9s.
    By pablo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th April 2008, 19:17
  5. fmic fitting guide?
    By jimya4t in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th February 2007, 10:43
