JMB RetrofitsChris Nott
    Jan 2005
    UK
    19
    Rusty engine part
    Hi all,
    I have an 18 month old A3 Tdi Sport and I have noticed a part under the bonnet getting more and more rusty each time I check the oil, it is at the front of the engine bay and just behind the drivers headlight, it has pipes coming out of the topthe top of this unit is completely rusty, have any of you with the same car having the same problem?........was thinking of going back to the dealer to have it changed as it looks really bad and isnt what you expect from an 18 month old Audi.
    Mar 2003
    UK
    426
    Re: Rusty engine part
    I think it is part of the climate control and is called the condenser, I think. During winter, salt collects on the top and starts to rust a little bit. I just spray some WD40 on it to slow down the rusting process, but it's nothing to worry about. Take a look at the under side of the car some time, and your catalytic converter!
    Jan 2005
    UK
    19
    Thanks, will spray some WD40 next time I'm under the hood.
