Volks AutosChris Nott
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By gilberto
Thread: Single mass or dual mass fly wheel S3??!
    Aug 2013
    25
    Sorry if this has already been covered but just wondered what option you guys went for!! Also what are the pros and cons of both?! Any help will be appreciated as I'm abit of a novice
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    single mass loba/sachs over here. it's a bit louder, pedal is a bit harder too. sometimes there's rattle, most of the times there isn't. pros: it can handle a lot more power and abuse.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Jan 2009
    125
    Went the single mass Loba/Sachs combination too. Basically as S. describes above. It is a fairly heavy clutch not ideal for sitting in traffic stopping and starting. The rattle on idle doesn't sound healthy. Apart from those things I'm glad I chose it, great bite in the low gears.
    S. likes this.
    S3 Revo Stage 2+
    Milltek Non Res-ITG-Autotech HPFP-Loba SMF
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,368
    Depends on what you want,and how you treat a clutch.
    If you want to retain the stock feel,then the Sachs organic and LUK DMF will cope with up to and maybe a bit over,400lbs.
    It will not,however,cope with a lot of drag style starts.
    The Loba/SMF is tougher,but there is the harshness aspect,which isn't bad,but will be noticeable at idle.
    Jul 2013
    311
    i just got a loba kit and the only down fall i can find is slow traffic/start stop as mine is a bit juddery when you let the clutch out , but it not to bad if you can just let it out fast
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Loba/sach here too. Have to put a little more revs on when setting off, which doesn't bother me as I like to hear the milltek anyway :D
    Aug 2013
    25
    Thanks for the replies guys, thinking about getting the single mass flywheel and Sachs clutch just abit worried about the chatter?!
    Jul 2013
    311
    Chatter ident bad to be honest I think once I put an extra .5 of a ltr in the box it will be as good is silent ! Mine only chatters noticeably when on a reasonable slope
    Aug 2013
    25
    That's good to know, time to get saving my pennies then
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by s3_sid View Post
    In what box? Mine only chatters on a slope too, but by engaging the clutch and letting it out again the chatter tends to disappear.
    Jul 2013
    311
    In the gearbox its a trick people used to do on the mk4 tdi's as the rattle like crazy and it shuts them up a bit so just park on a hill with its front end point up and put a touch more 6 speed Vw own oil in all other stuff is rubbish !
  1. has my dual mass fly wheel had it?
    By doughty29 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2013, 10:38
  2. Replacing dual mass fly wheel with a solid?
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th February 2012, 20:40
  3. single mass or dual mass whats the difference
    By flying oyster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th February 2010, 00:46
  4. Dual mass fly wheel???
    By stu86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th September 2009, 11:36
  5. clutch facts, single & dual mass ectectect
    By cornish_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2008, 20:34
