Volks AutosMonster Motorsport
    Mar 2013
    West Yorksire
    24
    Clutch slipping advice
    Hi all .
    Recently my Audi A3 clutch has started to slip in high gear and the the biteing point has come very high. I just was wondering would i need to change the flywheel aswell as it is a dual mass . I have had no problems with the flywheel juddering or making any noise and the clutch and flywheel where changed in jan 2012 but i think they where second hand. Can i get away with just changing the clutch or will i have to go all in .
    Thanks all
    Jun 2013
    104
    I would change the flywheel as well mate as the gearbox will be off!
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    277
    You've done half a job before and it bit you in the ass, do a proper job this time. If you'd had new parts last time you wouldn't need to be doing it again.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Change the release bearing as well - only £40 or there abouts!
  1. S3 clutch slipping !! Advice please...
    By CJ3BLUE in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st December 2009, 16:39
  2. Clutch slip! & another problem
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2005, 23:33
  3. is my clutch slipping?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2004, 19:29
  4. chipped A3 tdiq clutch slipping....anyone else??
    By A3Lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 23:38
  5. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
