Results 1 to 7 of 7
    May 2009
    6
    A3 sline black add headlight
    I have a 2010 A3 black addition s line 2.0 TDI with xeon and led headlight Yesterday I hit a bird and the plastic is broken
    Does anyone know if and where I can get a replacement 'glass' or a part exchange refurb company It seams a waste to have to buy a new light fitting when it all works perfectly esp in these days of recycling .. Thanks
    Jun 2011
    Wellingborough
    1,127
    Whats broken on the lamp? The outside?
    i would think the cheapest way to do this is to buy a used halogen headlamp on ebay, heat the lense off it, break yours out, clean the old sealent out and put the new lense on with some new sealent.
    i can do the job if required but would want the doner headlight supplied. Also try not get water and moisture into this light or it will ruin them.
    Same thing happened on my mates X5, he left it for so long he ended up having to go through insurance as the new headlamp with all the trimmings was 1k.
    Trups
    Bi Xenon Projector kits starting at £79.99 per pair.
    EM Tuning Lighting.
    May 2009
    6
    yes just the outside is Brocken all works perfectly ok
    Jun 2011
    Wellingborough
    1,127
    ok.
    here are some damaged cheap ones:
    RH: AUDI A3 FACELIFT RH HEADLIGHT 8P0 941 004 | eBay
    LH - Genuine Audi A3 8P Facelift Headlight Lamp Unit N/S/F 2009- (8P0941003) [65] | eBay
    i would try and keep it dry and not use untill its fixed, if you are good at small jobs this will be easy for you to do.
    Trups
    EM Tuning Lighting.
    May 2009
    6
    THanks for that so the plastic on that light will fit my light the first bit of part no is the same but second bit different I take it first part is size ect and second variation
    Jun 2011
    Wellingborough
    1,127
    yes. shape of the light on the halogen is the same as the xenon.
    By a broken light like in the links and strip it, then do the same with your xenon, clean out the channels where the sealent was and put new sealent in, heat it up with a heatgun and put them in.
    you will need the bumper off to carry out the work, or get a local garage to do the work.
    Trups
    EM Tuning Lighting.
    May 2009
    6
    Thanks you are a life saver
  1. STOLEN A3 SLine Black Edition
    By HLZ Bells in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2012, 17:50
  2. STOLEN A3 SLine Black Edition
    By HLZ Bells in forum General Chat
    Last Post: 9th May 2012, 21:40
  3. STOLEN A3 SLine Black Edition
    By HLZ Bells in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th May 2012, 16:15
  4. STOLEN A3 SLine Black Edition
    By HLZ Bells in forum General Automotive Chat
    Last Post: 9th May 2012, 15:13
  5. White A3 Sline Black Edition
    By HUgradar in forum The Welcome Section
    Last Post: 27th April 2011, 19:00
