Sky InsuranceAH Fabrications
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By JohnE
Thread: Audi aux some diy needs doing
    slizza786's Avatar
    Aug 2013
    123
    Hi guys
    I finally managed to fit a aux connection to the car and the way I have the 3.5mm hanging out makes the head unit not fit in snuggly so I need to do abit of chizzling/cutting of the head unit to get a snug fit.
    Because of the the material of the plastic of the head unit I'm not sure what I can use to cut abit of the material off, would anyone know what tool would be most effective?
    Have a look at the attached pic!
    Mar 2012
    295
    I would use the switch blank next to the ESP switch to exit that cable if I were you, but if you want to hack the head unit a Dremel or equivalent is probably the best bet.
    Sidhu88 likes this.
    slizza786's Avatar
    Aug 2013
    123
    Nice idea of the blank such after work Il check if that I can manage to run my hands through there
    Dec 2012
    205
    I ran mine downwards behind the climate control and out where most people have an ashtray in the centre, forward of the gearstick (mine has no ashtray)
    buz
    Flat out
    Mar 2013
    Hereford
    51
    Could you not somehow feed it up from behind the head unit and into the air vent? That would hide all the wire except for the tiny bit between vent and phone.
    My OCD would make me find a better solution than this
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    Run it to next the handbrake and have a female connector there, make it look oem!
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Feb 2011
    Plymouth
    939
    female connector in the blank is what i'd do
    slizza786's Avatar
    Aug 2013
    123
    Thanks guys! It's very hard to run through the air vent! As for the female connector that would make it look much smarter but it's very hard going to the blank =S
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Quote Originally Posted by buz View Post
    An airvent is a sealed unit... You could do that if you want to muck up your circulation...
    if you want keep it where it is.. Then blanking plate and some cable ties behind the bracket, is your best option + its easier to replace a blanking plate than it is to hide a notch in the dash...
    slizza786's Avatar
    Aug 2013
    123
    Quote Originally Posted by S3_Jacko View Post
    Thanks for all the tips and advice guys really appreciate it. I decided to go the blank button route and credit where due, with great advice from Jacko I managed to clean it up in under 30mins.very happy with the job just going to get some cable tie and wrap it behind the holder tmrw.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Quote Originally Posted by slizza786 View Post
    Looks good.. couple of cable ties will finish that off quite nicely
    buz
    Flat out
    Mar 2013
    Hereford
    51
    That's better, a much neater outcome.
  1. Audi A4 B5 DIY Library
    By Olly_K in forum General Technical / How To
    Last Post: 4th June 2008, 13:35
  2. audi-thermostat-do i need one?????????
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2007, 10:47
  3. Replies: 3
    Last Post: 13th April 2006, 13:11
  4. Looking at 96 P reg Audi A4 1.8T, need advice!!
    By somefuka in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2004, 15:12
