Badger5Monster Motorsport
    Oct 2013
    Nottingham
    12
    Starting troubles
    I have read through a few posts on this topic, and im still a little unsure where to start looking for issues with this. I was having trouble for a few days a couple of months ago where the starter would turn the engine a little longer than normal before it fired. Over about a week, this got gradually worse, until it didnt start at all. However, it started straight away every time after being stood all day at work (9hrs). I tried jump starting, and it fired straight up after being stood fopr two days. I bought a new battery, did a service, (fuel/oil/air filters, oil ect) and this seemed to sort the problem. That was a month ago. This morning, it was a little colder than normal, (9°C) and it struggled to start. I have bought some glow plugs, which I will try but I thought that they only worked in very cold conditions anyway? Does anybody have any ideas what I can check or what may be causing the issue?
    My thoughts are - Starter motor works fine with new battery and when jump starting, so unlikely
    - Its not that cold so glow plugs wont make much difference
    - fuel pump - last resort to change, although know this model has fuel and oil pump issues!
    - Could it be a short that the damp/cold effects?
    This is for a 2006 2.0TDI 170 Any advice appreciated, will also check the voltage from alternator tonight. Sorry for the long post!
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    What battery did you get? Also maybe there is something that drains the battery.
    VCDS USER
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,450
    Alternator not charging up?
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,826
    Quote Originally Posted by woody83 View Post
    Faulty temperature sensor?
    2009 A3 SB 2.0T DSG S line
    Oct 2013
    Nottingham
    12
    It seems after I fitted the new battery, changed the glow plugs, and gave it a service, which was due anyway. The problem seemed to go away, put a meter across the alternator and this all looked fine. I now have trouble with the car going into limp mode, seems its been trouble ever sine I bought the thing!
  1. Starting troubles
    By Orangephoner in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2013, 19:12
  2. Intermittant cold start troubles
    By madstaff in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 13th November 2012, 20:03
  3. Cold starting trouble!
    By HOTFUZZ007 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd February 2009, 07:49
  4. Trouble Starting
    By krazpony1 in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 8th December 2007, 17:12
  5. A6 trouble starting
    By accordny in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 10th April 2004, 20:55
Tags for this Thread
