EM TuningSky Insurance
Results 1 to 14 of 14
    Dec 2011
    MIDLANDS
    241
    2.0 tdi passenger door lock fault 3 door 2007
    Hi guys I feel like my car is falling apart!!
    i also have a problem where by the passenger door can not be opened from the outside after it has been locked by the key fob. If it is opened from the inside manually then the door handle on the outside is functional again.
    A scan shows that the lock mechanism and solenoid (same part) is at fault.
    Does any one know how much a new unit will cost? And where the best place to get one from?
    cheers
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    26,747
    Dejavous, its £143 for new lock, it needs removing & cleaning.
    Dec 2011
    MIDLANDS
    241
    My existing one needs removing and cleaning? If so what's the best way to clean it and which part of it?
    thanks Nigel
    26,747
    Take it out & take apart, then check for crap build up & clean, I did advise this before tbh, it may save you £143.
    Dec 2011
    MIDLANDS
    241
    Thanks Nigel, I must of missed this before. I will take it off at work tomorrow and give it a good clean. Wd40 ok to use on the inside of the lock mech? Is there any other issue I should watch out for when reinstalling the lock?
    cheers
    Dec 2011
    MIDLANDS
    241
    the problem is that the bottom actuator on the bottom limit switch within the lock is not returning to the correct position and engaging the external handle
    how can this be freed off??
    26,747
    Microswitch I assume?
    Pics would be a help.
    Dec 2011
    MIDLANDS
    241
    The pic shows the arrow of the part that is not returning. its not the actual limit switch is is the actuator that pushes the limit switch in? therefore with this not returning it is making the external handle mechanism not return so the door handle from outside will not work.lock.jpg
    26,747
    Want to make the pic any smaller lol.
    Dec 2011
    MIDLANDS
    241
    Haha couldn't get it to go any bigger !
    Feb 2013
    128
    I'd be interested to see if you get this resolved cheaply because my rear passenger door does this now, it's fine when you open it from the inside and then shut it, then re-open it... not a problem. But when it's been locked, try and open it, not a chance - although on one occasion I have opened it by quickly "flapping" the handle for a few seconds!
    Audi A3 2007 2.0TDI 170 Quattro S-Line Sportback, fully kitted
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    795
    Mines does exactly the same as above on my 5 door on the Leon I had we saturated the lock in IPA as it evaporates unlike wd40 that leaves a film
    Growing old is mandatory, growing up is optional
    Dec 2011
    MIDLANDS
    241
    I've just purchased a second had one off the good old auction site. £25 delivered so hoping for it to come tomorrow or Tuesday!
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    795
    Is there a guide anywhere, on replacement?
  1. New VCDS Cable - Door Locking Fault ??
    By Tinners in forum VCDS (formerly VAG-COM) forum
    Last Post: 25th October 2012, 13:15
  2. New VCDS Cable - Door Locking Fault ??
    By Tinners in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th October 2012, 21:29
  3. Rear passenger door locking
    By lscolman2 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th March 2011, 14:57
  4. Door lock, windows fault
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st June 2005, 17:15
