Volks AutosMonster Motorsport
    Sep 2011
    Reading
    50
    A3 sline rear springs
    Both broken on my 09 plate a3 black edition.
    phoned dealer in reading for a quote and was told can't buy just the springs need to get the rubber mounting bushes as well.
    seamed strange as they all come with different part no's.
    was £163 for 2 springs and 4 rubber bushes.
    can this be true?
    26,722
    £163 for rear springs & bushes seems fair price tbh, if you wanted to get better springs, give Damian@dpm a shout as he can supply a complete better aftermarket set like eibach pro's, for fair prices & usually the rubber parts are reused tbh.
    Sep 2011
    Reading
    50
    Thought the price was ok.
    Seen eibachs for around £180 but then extra cost to fit etc.
    Just want sline springs to be honest
    dantdi's Avatar
    Feb 2008
    kent
    511
    I recently had same Mike, Two broken back s line spring. After messing around with euro parts and getting wrong spring.
    I went foreibach pro's like NHN has already said. Got them from DPM to. All around better in my mind! Worth it id say.
    I just changed the front mounts and bearings £76.99 from TPS.
  1. rear springs.......
    By a4quat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2007, 20:51
  2. 1.8t SLINE LOWERING SPRINGS ADVICE
    By trini88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th August 2007, 01:01
  3. coilover rear springs.normal?
    By dultanur in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th May 2007, 12:00
  4. A4 Avant 2.5TDI Quattro rear springs - where?
    By tonycaterham123 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2006, 13:16
  5. Replacing rear spring - need to change in pairs?
    By AndrewB in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2005, 08:57
