Sky InsuranceVolks Autos
Like Tree5Likes
  • 1 Post By NHN
  • 2 Post By Artimus
  • 1 Post By Chillout
  • 1 Post By Geraldy212
Thread: Any Idea What Is Causing This? Rattle At 1000 RPM
    Feb 2013
    London
    20
    Unhappy Any Idea What Is Causing This? Rattle At 1000 RPM
    Recently this rattle has just come out of no where. I'm not sure what it could be..
    Its only when I accelerate or keep it around 1000rpm that it makes this noise. When the car is cold, theres no sound of the rattle at all, only when it has warmed up. It doesnt affect the way the car drives, but sometimes when I want to drive without the radio on, it is ANNOYING!
    Heres a video...
    Its a 2004 Audi A3 FSI 2.0 with 59k on the clock.
    It sounds like the rattle is coming from behind the dash, but also under the car. You may have to turn the volume up full to hear it as I recorded it on my phone.
    Any suggestions?
    Thanks in advance
    27,099
    You'll need to get under there with a torch & bar maybe to find that tbh, could be a multitude of things.
    Lz36 likes this.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,867
    for some reason I'm only hearing sound when you open the door, and even then there's no excessive rattle evident???
    But just for sh*ts & giggles: Exhaust heat shields have a tendency to come loose of their own accord sometimes & that's what I'd be checking first.
    NHN and Lz36 like this.
    2009 A3 SB 2.0T DSG S line
    Apr 2013
    Aberdeenshire
    592
    [QUOTE=Artimus;1985235]for some reason I'm only hearing sound when you open the door, and even then there's no excessive rattle evident???
    But just for sh*ts & giggles: Exhaust heat shields have a tendency to come loose of their own accord sometimes & that's what I'd be checking first.[/
    I think he has kidnapped Woody the Wood pecker,
    on serous note though how is your flywheel, Alternator pulley or can you hear it only at certain revs or over bumps or cobbled streets they are a good test surface.
    Lz36 likes this.
    Sportback owner
    Apr 2007
    France
    492
    LZ, as NHN has said, get underneath and run the car at 1000rpm. Take a wooden stick and gently touch anything that looks fragile. Something is resonating at 1000cps, and the wooden stick will deaden it right away. Yes, a suspect could be heat shields, covers, loose pipes, almost anything free to move a bit. Also check under the bonnet for the same noise, which could come from the alternator pulley or anything ever so slightly loose. Good luck.
    Lz36 likes this.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Feb 2013
    London
    20
    I appreciate the replies!
    Turned out to be the fuel pipes rattling against the body housing. Quick fix from my local garage. Glad it was nothing serious!
  1. ANYONE ANY IDEA WHAT THIS LOOSE WIRE IS BEHIND CLIMATE CONTROL UNIT
    By tommytonguedj in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd June 2012, 10:13
  2. Any idea what this is?
    By reptor245 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2009, 17:18
  3. Any ideas what this could be ?.....
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th October 2008, 00:38
  4. any ideas how to do this?
    By sdl3884 in forum The Welcome Section
    Last Post: 10th December 2004, 19:41
  5. wandering xenon headlight - any ideas whats wrong
    By dunk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2003, 13:10
