JMB RetrofitsAH Fabrications
    Jul 2013
    Abs and traction control warning light
    Hi,
    I have a 2004 Audi A3 and my Abs and Traction control light come on after around 40mph and stay on until i turn the ignition off, anyone had this problem and possible causes? Also how I can fix this problem? Thanks
    T33_BKD's Avatar
    Browser
    Apr 2013
    London
    58
    Visit T33_BKD's Instagram Channel
    Hi, I currently have this on my 06 2.0tdi, a scan shows that it's the rear right abs sensor/wheel bearing. After reading a few threads on here suggests that replacing the wheel bearing fixes this(common fault) . Perhaps a scan will give you more info. I'm Looking to get the wheel bearing replaced soon, but not in any rush as it's not really causing any other problems.
    J8TT X's Avatar
    Jan 2011
    Leicester
    337
    I had this the other day, it came on and off for 2 days and now has gone.
    You need to get it scanned and it will tell you what's wrong.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    27,086
    Quote Originally Posted by Wels1 View Post
    Hi,
    As already advised, it needs a scan tbh as there are various possible reasons for this, from steering rack, to abs sensors, bearings, steering angle sensor etc.
    Mar 2013
    Edinburgh
    15
    I have the exact same problem at the moment. Nightmare as I'm looking to sell up soon.
    May 2009
    6
    Same thing happened on my 55 TDI It needed a new abs unit there is an electronic part that is failing common I was told got a refurb part x unit all fitted by my local independent garage for £120.00
  1. Abs and traction control lights on dash after installation of new shape brake switch
    By Sowerbalboa in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd September 2013, 10:58
  2. Traction Control Warning Light Coming On
    By adamf200 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th February 2011, 09:46
  3. ABS and Traction control light just came on
    By Jason-Con in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th August 2010, 07:35
  4. ABS and traction control light
    By joshwalters123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2009, 18:47
  5. Warning lights - the ABS and the parking brake light
    By vij31 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th March 2006, 16:10
