AH FabricationsEM Tuning
Results 1 to 18 of 18
Like Tree1Likes
  • 1 Post By H17YD L
Thread: DSG Woes & Turning engine off
    Feb 2012
    336
    Hi all,
    Must say I'm loving being the proud owner of a black edition and thank you to everyone who posted advice in my thread before I bought one.
    I'm just a little concerned about my DSG gearbox. Now I've taken it for a motorway and A-road drive and around town too so have covered all types of driving in it.
    It changes up smooth, kicks down nicely, the tiptronic mode is good, everything works as it should bar 2 things. The clank when it down shifts from 3rd to 2nd gear and very rarely 4th to 3rd. Now here's something I've noticed...(relatively speaking) when I brake harder its almost as though the box chucks itself into 3rd from 4th or 2nd from 3rd and that helps slowing the car down (and making the clunk), whereas if I brake more gently then the down changes happen with no noises at all and very smoothly...the best way I can describe is if you were driving a manual car, and you down changed before your speed was appropriate for the gear you were down changing into, you'd feel the car decelerate quickly and sharply if you took your foot of the clutch...any ideas?
    Secondly, and this happens more around town cos I drive with the window down and can hear it, again the box works perfectly but makes all sorts of weird and wonderful clicks and clunks sometimes...I'm almost starting to think they are made like that because it changes up/down fine, just makes some noise about it lol...does anyone know what it could be?
    Looking at its history, the box has had the oil and filter changes down on time every time and it was just recently done as part of a service before I bought the car.
    Maybe I can describe it this way.is the DSG built for giving the fastest gear change rather than the smoothest drive, or should it be doing both?
    And lastly, when I turn the engine off there is a squeak like a belt or tensioner type squeak from the right hand side of the engine if you're facing out when sat in the driver seat, which is the left hand side of the engine if you had your head under the bonnet. Again, does anyone have any ideas?
    Please be considerate with your advice (not that you arent) because I'm considering taking out a 3rd party warranty just incase for the gear box...
    thanks in advance
    PS Next week I'll be home in Yorkshire, any chance someone local could take me out in their car so I can try compare? Amongst my own friends the closest I have access to is a 2005 BKD DSG 140 but I'm guessing the engine/gearbox are totally different?
    bomasspot's Avatar
    Apr 2011
    Kent
    40
    With regard to your jerky gear changes it could just need calibrating with VCDS 6-Speed Direct Shift Gearbox (DSG/02E) - Ross-Tech Wiki if you have a cable or another member near you could do it for you. As for the squeak it may be a belt or tensioner-again someone would need to check whilst you switch off the engine.
    Feb 2012
    336
    I don't have a cable or any software unfortunately. What does the procedure outlined in the link do, just recalibrate the engage/disengage points and stuff for the box?
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,219
    Were you driving it in S or D?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Mar 2011
    Cleveland
    992
    Quote Originally Posted by Sayam View Post
    Should be the same, both Dsg.
    Dec 2012
    244
    How many miles has the car done and has it had the DSG oil changed?
    2010 Condor Grey S3 Sportback S-Tronic. 354bhp 414ft/lb.
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    320
    Quote Originally Posted by sliced View Post
    Quote Originally Posted by fangio View Post
    He asked this because in S the down gear changes are more abrupt than in D, almost sedate
    +incoming MY15 S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Dec 2012
    244
    I think Fangio was replying to the other question about whether the gearbox is the same as his friends 2.0TDI
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    320
    Aaaah yes, re-read.
    Feb 2012
    336
    I only ever drive in D, I've stepped up from a 115bhp diesel to this 170 so never feel the need to go into S.
    Car has 100K and yes all the DSG oil changes have been done, maybe 1 extra because its had 3 in total.
    Do you think its worth booking into the dealer to do a fresh oil change now I've got the car? Or can the diesel run some sort of diagnostic on it?
    Dec 2012
    244
    If the DSG oil changes where done at Audi I'd double check with them if they where done correctly, they will be on their system no matter what dealership they were done at. Then maybe see if they will be willing to look at it.
    Might be a mechatronic failure which cost quite a bit to sort out, google it to see if the symptoms are similar to yours.
    NHN likes this.
    Dec 2012
    244
    And the dealership can scan the car with their equipment which will show up and fault codes in the DSG. That's if the problem is severe enough to cause a fault code.
    Feb 2012
    336
    Been doing some more digging and the way that the symptoms are described on other forums it may be the subframe bolt problem. Most of the posts around this relate to MK5/6 Golf rather than the A3. Can anyone confirm if the 8P suffers from the same problem?
    Dec 2012
    244
    It certainly does, I replaced my bolts with the new type and fitted the shim in-between the sub-frame and chassis:
    ECS Subframe Spacer Plates Kit - Mk5/Mk6 etc. | Awesome GTI
    This cured my knocking when turning going over un-even surfaces.
    Feb 2012
    336
    Thank you
    Will this work as the listen engine says 2.0 tfsi but I have 2.0 tdi DSG
    Also I assume the golf mk5/6 and 8p a3 are same fitment?
    Taroni's Avatar
    Jan 2011
    Kent
    107
    mine was clonky I changed the dogmount now its fine
    A3 3.2 DSG Quattro
    Dec 2012
    244
    Thank you
    Yes it will, subframe is the same.
    Feb 2012
    336
    Quote Originally Posted by H17YD L View Post
    Cool, thank you.
  1. Metallic clicking when turn my engine off :/
    By ben681 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2012, 21:08
  2. funny noise when i turn engine off
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2011, 11:54
  3. Rattle / knock when turning engine off
    By Endacy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2011, 19:00
  4. Folding mirrors when you turn engine off?
    By lil_coz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2011, 23:42
  5. Can i turn AVS off?
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2005, 20:39
