Chris NottMonster Motorsport
Results 1 to 17 of 17
    Jun 2013
    Bridlington
    144
    Right dipped headlight warning...
    Well this might be a strange one, i'm basically getting this warning message on my dash saying 'Right dipped headlight warning' but my headlights work fine and it comes warning me all the time. It will come on for 10/15 seconds then go off then come back after 10/15 seconds, any ideas what this could be? maybe a disturbed sensor?
    Jun 2013
    Bridlington
    144
    bumpyy
    Sportback owner
    Apr 2007
    France
    492
    Some possibilities: Try changing the bulb, or at least plugging it in and out to clean the contacts, check the earth wiring (brown) on the RH unit, or perhaps the on-board supply control unit (electronic box that supplies power to all front lamps) may be faulty and sending the wrong signal on the CAN bus. Sounds a bit like a contact problem (intermittent high resistance) somewhere. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    Jun 2013
    Bridlington
    144
    Quote Originally Posted by Geraldy212 View Post
    Thanks for the reply, first thing i'll try is pull the bulb out and clean the contacts and plug it back in seems like a simple enough job!
    Mar 2011
    Cleveland
    979
    Not self-levelling fault, is it? (If you have them, that is!)
    Jun 2013
    Bridlington
    144
    Quote Originally Posted by fangio View Post
    I have no idea, i can manually adjust them though!
    Mar 2011
    Cleveland
    979
    Check it's going up and down, must be lit and ignition on.
    If it's OK, at least it rules that out!
    Jun 2013
    Bridlington
    144
    Will check this tonight and report back, really appreciate the help guys!
    Jun 2013
    Bridlington
    144
    Well little update on things, went out in the car last night and my right side light didn't come on but after a few minutes of driving it came on, so i'm guessing the bulb is on it's way out, anyone got a link to buy OEM bulbs from? (don't want another error message for having the wrong bulbs)
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,109
    Not necessarily the bulb mate. If it went off and then on again, this would suggest to me it is a wiring issue. Check the wires on back if connector are all intact properly and no corrosion etc. Had a similar problem few years ago but on the rear.
    I doubt it very much is the bulb, but could be wrong.
    But in the case if it is the bulbs then don't buy from the stealers as they will charge a fortune. You can get the same bulbs for less from places like eurocarparts etc. I believe the oem bulbs are by phillips.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Jun 2013
    Bridlington
    144
    Quote Originally Posted by Dannykn9 View Post
    Coming to think of it i did have some work done on the car last week and it's only started since then so i'll have check that and could possibly be loose!
    Mar 2012
    369
    I've had a bulb fail in this mode - if the filament is burning out and collapsing - but as had been said, it's not common. I'm impressed with Audi's warning system - would be good if other cars had it judging by the number of cars I see with brake lights, headlights etc not working.
    Jun 2013
    Bridlington
    144
    Quote Originally Posted by JohnE View Post
    So are you saying it could be the bulb or the wiring? i am impressed with the warning system too! just annoying when it makes a noise every 15 seconds
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,109
    To check if it is the bulb, swap it with the left one and see if problem resolves. If so, you have found your problem, if not then as said, could be wiring/dodgy connection.
    Jun 2013
    Bridlington
    144
    Great idea, i shall try that (saves me buying one for now) also i'm guessing it's simple to replace the bulb? heard about A4's being a pain to get to, A3's any different?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,109
    A bit fiddly, but easy enough.
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    896
    Quote Originally Posted by tally2425 View Post
    I used long nosed pliers, if you use a mirror to see what you're doing in the first place it is quite easy.
    Growing old is mandatory, growing up is optional
  1. Right Dipped Headlight Bulb Change
    By jon1984 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd January 2012, 11:50
  2. Blown Dipped Headlight
    By mattypgolf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th April 2009, 01:05
  3. Dipped headlight not working
    By m40rcd in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th October 2008, 11:23
  4. Fitting a front dipping headlight bulb
    By peter02 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th January 2008, 19:32
  5. dipped headlight bulbs
    By DeanA4TDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2007, 23:29
