AH FabricationsJMB Retrofits
    credster's Avatar
    Dec 2012
    16
    Unhappy coolant pump 2 fault
    hi there wonder if anyone can help or throw some light on this problem I have my audi a3 1.6 tdi has thrown up an engine warning light and is going into limp mode the only way to get it running ok again is to turn the engine off then back on
    then it runsok for a while then it happens again !!
    have connected to vagcom and it reads as follows
    1 fault found
    9870- coolant pump 2
    p261b 00 (232) implausible signal
    any help would be grateful
    thanks
    tony
    27,099
    It kind of advises where the issue appears to be tbh Tony, being a 1.6 tdi, I would maybe consider asking audi to address it under goodwill if its only just out of warranty as those engines aren't that old tbh.
    credster's Avatar
    Dec 2012
    16
    thanks for the quick reply im not so sure goodwill will come into it my car is a 2010 but as my engines just hit 103000 mls maybe wasting my time . worth a go though will call in tomorrow
    thanks
    tony
    credster's Avatar
    Dec 2012
    16
    problem seems to have sorted itself wow result hehe
    thanks again
  1. Continued coolant pump
    By S3BLX in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th February 2009, 20:55
  2. Oil or coolant pump ? once engine switched off ?
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2007, 23:06
  3. Coolant system fault ?
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd April 2007, 14:15
  4. Quick question. Coolant system fault?
    By portsA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2007, 08:20
  5. 8L A3 ABS Pump Fault & Repair!
    By Tallpaul in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th June 2006, 15:37
