Volks AutosMonster Motorsport
Like Tree1Likes
  • 1 Post By Sayam
Thread: EML Warning Light and Fault Codes
    Jan 2012
    112
    After taking my car for a service I was advised of the following from them.
    Warning lamps - eml on - 3 faults stored, ecm disabled, coolant fan blocked,
    egr valve electric fault. For them to just do the diagnosis was £138 I figured that the diagnosis might be just them giving me a print out of the fault codes from the VCDS so I declined. I arranged to meet a kind forum member SAiLO who did a scan for me. I've changed a few things without clearing codes in the past so I think the 1st scan included things that wern't cleared before.
    This is the light that is on. I think it's the EML light? What does MIL stand for? does it represent the same light as the picture below?
    The DTC's / faults were cleared and the warning light went off for about 2 hours before poping back on again. I had a second reading done today and the results are below. I would appreciate any help or advice on how I can get them cleared. The bolded ones seem to be more concerning to me.
    VCDS Version: Release 12.12.0 (x64)
    Friday,04,October,2013,14:55:14:26151
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56
    VIN: WAUZZZ8PX5A031138 Mileage: 139310km/86563miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010 -----(*Just a note, on the 1st scan a few days ago this didn't show up*)
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010 -----(*I think this is because I ain't got a CD changer installed*)
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010 -----(*My sound system seems to work ok, radio, cdplayer, mp3*)
    Address 01: Engine Labels: None
    Part No SW: 06F 906 056 CE HW: Hardware No
    Component: MED9.5.10 00 7000
    Revision: 00000000 Serial number: AUX7Z0D7FN60CW
    Coding: 0000072
    Shop #: WSC 06435 000 00000
    VCID: 6ED3223F79F1226E76F-803B
    Subsystem 1 - Part No: 06F 907 807 D
    Component: NOX 0408060030 006 4109
    06F907807D NOX 0408060030 006 4109
    1 Fault Found:
    17808 - EGR Valve (N18)
    P1400 - 002 - Electrical Malfunction - MIL ON
    Readiness: 0010 0101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021126
    VCID: 3A7BDE6F7539BECE9A7-806F
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 G HW: 8P0 820 043 G
    Component: KlimavollautomatH12 0150
    Revision: 005265 Serial number: 8P0820043G
    Shop #: WSC 00000 000 00000
    VCID: 306FFC47A345749E243-8065
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 139274 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 20:44:25
    Freeze Frame:
    Voltage: 12.00 V
    Temperature: 21.5°C
    (no units): 28.0
    (no units): 31.0
    Temperature: 19.0°C
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H30 0701
    Revision: 00030000 Serial number: 00000000748103
    Coding: 018CCF00A0141000000000000000000000
    VCID: 3E73D27F691192EEA6F-806B
    Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    2 Faults Found:
    01341 - Control Module in Instrument Panel On Comfort CAN (J285)
    004 - No Signal/Communication - Intermittent
    00466 - Control Module for Steering Column Electronics (J527)
    Address 15: Airbags Labels: 8P0-959-655-84.lbl
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0140
    Coding: 0011602
    VCID: 4385A38B02F3FF06C91-8016
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 980 M HW: 8P0 920 980 M
    Component: KOMBIINSTR. VDO H71 0210
    Revision: D03 Serial number: 2247DD03001449
    Coding: 0004408
    Shop #: WSC 56434 000 1048576
    VCID: 4189A98318EFED16DBD-8014
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001048030225
    Coding: 3D0F034A070101
    VCID: 285F14279B953C5EFC3-807D
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D03 Serial number: AUX7Z0D7FN60CW
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 HW: 8P0 035 192
    Component: RNS-E HIGH EU H56 0650
    Revision: 08S Serial number: AUZBZ7E0304060
    Coding: 0225113
    Shop #: WSC 00262 210 58386
    VCID: ECD7A837CFED507ED8B-80B9
    1 Fault Found:
    00857 - CD Changer Unit (R41)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 28
    Mileage: 139267 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 19:50:20
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    VCID: 3D71D573641789F6BF5-8068
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 008000186D288505489AC63000
    VCID: F9F98163B0BFF5D653D-80AC
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Subsystem 3 - Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH25 0160
    Revision: 00003 Serial number: 10000001162547
    VCID: F0EFBC47E3C5B49EE43-80A5
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
    Part No: 8P0 959 802 E
    Coding: 0000048
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0225113
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 28
    Mileage: 139267 km
    Time Indication: 0
    Date: 2013.10.01
    Time: 19:50:20
    Jan 2012
    112
    bump, can anybody help me please.
    Mainly with these ones, looking up the codes on Ross-Tech wiki they both don't come up.
    Coding: 0000072
    1 Fault Found:
    Coding: 00062736
    Shop #: WSC 00000
    2 Faults Found:
    Jan 2012
    112
    I have the same code coming up after a recent scan. I did the scan as the eml light popped up and I've noticed that my car sounds a little louder than usual when driving on the dual carriage way. Does anybody know what the problem code could mean?
    P1400 - 002 - Electrical Malfunction - Intermittent - MIL ON
    Readiness: 0010 0001
    Jan 2012
    112
    Anybody?
    Feb 2012
    338
    http://engine-codes.com/p1400_audi.html
    Just googled it quick
    Maybe worth removing and cleaning the egr valve?
    dk1234 likes this.
  1. Audi A4 B8 Door Warning Light and Puddle Light retro fit
    By pns2007 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 10th April 2014, 13:53
  2. Engine Warning Light - Have fault codes - don't know if its a concern.
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th June 2012, 20:02
  3. Replies: 2
    Last Post: 19th December 2010, 20:41
  4. Puddle, warning lights and door handles
    By Relaxitscool in forum Parts Requests
    Last Post: 10th February 2010, 14:55
  5. coolant warning light and buzzer.
    By imported_55spike55 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 19:38
Tags for this Thread
