    Oct 2013
    kingsbridge devon
    13
    Follow DA55TER On Twitter
    coolant issues...
    Hi everyone.
    New to the forums, but I own 2 so needed to find some like minded petrol heads.
    My problem is with my 55 plate A3 2.0tdi
    The expansion bottle seems to fill with air, and expand, pushing all the water/coolant out. Lighting up the coolant level warning light.
    Ive had the expansion bottle and the thermostat replaced. But it still happens after a long drive. But then I stop and relieve the pressure light goes off, all is well until I take another long drive.
    Temperature stays at constant 90, fan kicks in, mechanic who replaced the parts is also scratching his head.
    He did notice alot of K-seal in the coolant. Could this be clogging the pipes? Or the waterpump?
    Any help would be greatly appreciated.
    Cheers.
    Apr 2013
    Aberdeenshire
    590
    Quote Originally Posted by DA55TER View Post
    Hi everyone.
    Cheers.
    Do you have a good flow as it sounds a bit like you have a water pump issue ,coolant is meant to be pressurised as this increases the boiling I would flush it well I don't like k seal or such ,I would flush it and refill it and make sure you have no air locks
    you could have a head/gasket issue but that's worst case scenario !
    check the hoses for air by squeezing them and ensuring they are both hot ,check for flow by looking at the small return pipe on the top of the header tank ,have it pressure tested or combustion gas tested.
    Radiators were common failures at the end that could explain the k seal.
    also so the cap could be faulty it has a pressure relief in it
  1. A3 Coolant Issues
    By smudge41 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2010, 08:00
  2. Help ; A3 55 plate engine management/temperature coolant issues.
    By heidimac in forum The Welcome Section
    Last Post: 23rd May 2010, 18:04
  3. URGENT HELP NEEDEED!!!!! COOLANT ISSUE
    By boya in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th December 2009, 08:14
  4. More Coolant issues! Beyond a joke now!!
    By IkonA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th November 2009, 18:56
  5. HELP! Coolant Issue!
    Last Post: 4th September 2009, 12:48
