EM TuningSky Insurance
Results 1 to 9 of 9
Like Tree2Likes
  • 2 Post By S3Alex
Thread: Dsg Clutch Slip
    Mar 2011
    Cleveland
    871
    Dsg Clutch Slip
    Hi, does anyone know if a dsg clutch can slip and if so, how to fix it?
    Ta!
    Pete
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,791
    Quote Originally Posted by fangio View Post
    Ta!
    Pete
    Yes it can,but how to fix it will depend on what caused it.
    If you're running much over stock torque,the software can be remapped in some cases to raise the clamping pressure of the clutch,and much over 400lbs would mean a rebuild with uprated clutch plates.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,161
    Check Youtube, video on there how to correctly change the two clutch plates.
    Mar 2011
    Cleveland
    871
    Stock power, 140. It just sounds as if it slips if I labour it (below 1400 rpm) in manual uphill. It 'groans'!
    Change down and it takes full throttle no problem....
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    out of interest, How many miles has it done/
    2009 A3 SB 2.0T DSG S line
    Mar 2011
    Cleveland
    871
    59000, dsg oil and filter at 45000 when I bought it. First thing I did!
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,625
    The reason I ask is because I have a similar sensation with my Bluefin'd petrol car. It produces roughly equal torque to yours & I don't boot it regularly, but when I plant my foot in "D" I get a slight rise in revs before kickdown & the car moves on! It's a more instant reaction in "S" mode, which feels like it has a more aggressive clutch bite.
    I put it down to the stock DSG software taking its own sweet lazy time to react for a smoother & more relaxed gear change, and I can certainly identify with what Alex posted about clamping pressures above. Even for Manual mode, it makes total sense that the software would limit certain parameters differently in different driving modes.
    Have you tried it in S mode to see if the bite improves? at least then you can maybe get an idea if the clutch still has any ...erm ...teeth left.
    Mar 2011
    Cleveland
    871
    Never needed S mode! I'll give it a go.
    It can't be serious as it was like it when I bought it 26 months ago.
    I quite like S3Alex's suggestion about the clamping pressure. Might pop into Teesside Audi!
    Sep 2013
    11
    I have a similar problem and my local geabox specialist says it is classic and needs a clutch plate replacement, there are 2 of them.
  1. DSG Clutch problems
    By OutLore in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th September 2005, 20:34
  2. Clutch slip! & another problem
    By IanMcA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2005, 23:33
  3. is my clutch slipping?
    By imported_bpascua in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th July 2004, 19:29
  4. chipped A3 tdiq clutch slipping....anyone else??
    By A3Lee in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 23:38
  5. clutch (slipping?)
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2003, 12:29
