Badger5Monster Motorsport
    Sep 2013
    38
    A3 2.0 Tdi 140 BKD - vibration on idle
    Evening all,
    Car = 2004 A3, 2.0 Tdi 140, DSG (BKD engine) on around 91k miles
    The car runs very smooth and produces good power from tickover to around 4k. The problem I have is when the engine is warm (anything above 70degrees approx) but especially when the engine has been running for a long time (20 mins plus) when the car is put into either neutral or park, there wil be a strong vibation/juddering on idle. It is so strong that even passengers have commented on it. This does not happen when the engine is cold and also stops IMMEDIATELY as soon as the car is put into Drive or Reverse. No funny noises and seems to drive fine upto speeds of well in excess of 100mph with no other issues. (I travel to Germany every few months)
    Any ideas?
    Sep 2013
    Croatia, Koprivnica
    7
    maybe some of engine mount is in the bad condition, and needs a change.
    J8TT X's Avatar
    Jan 2011
    Leicester
    338
    Engine Mount, Gearbox mount, Flywheel should all be checked
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Oct 2012
    Warrington, North West
    986
    Mine was same symptoms as yours and it was the DMF in its early stages of going. Is there a noise to go with the shaking?
    27,126
    Yeap as above, mounts would be my 1st choice, 04 car doubt they've ever been changed.
  1. Replies: 27
    Last Post: 1st January 2014, 13:39
  2. lift pump question 2.0 tdi 140 bkd
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 06:29
  3. Boost issues TDi 140 BKD
    By n25gabe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 12:35
  4. audi a3 2.0 tdi 140 BKD 8P Turbo removal? Help!!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 23:30
  5. A3 2.0 TDI 140 BKD Juddering 5th/6th Gears under load
    By a3sportback54 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2010, 11:13
