EM TuningBadger5
    Oct 2013
    15
    HID-Xenon Ballast
    The ballast appears to have gone in both sides of my 2006 2.0TDI A3. It's the S-Line with auto adjust. I'm needing to know exactly what type of bulbs these take? I simply can't afford the main dealer prices so I'm trying to locate either ballast online such as ebay or complete aftermarket kits to fit in as a replacement. Any help would be hugely appreciated as the MOT is also fast approaching!
    Thanks,
    James
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by CA51HAM View Post
    Thanks,
    James
    Bulbs can't be checked with by a multimeter however I would swap your bulbs around I would have thought it would have been unlikely for 2 ballasts to fail without a common problem .
    do you have vcds to scan it for codes.
    Oct 2013
    15
    The left often flashes and flickers until it goes out....and sometimes the right will do. They have been doing it for the past 18 months but getting worse. They would never both go out, until last week! When they did, a little bit scary!
    If you turn the lights off then on again then they will come back on, then start the process over again.
    Apr 2013
    Aberdeenshire
    595
    I would check for bad earths also
  1. hid/xenon conversion
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2007, 18:26
  2. HID Xenon lighting system
    By rne in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 6th July 2006, 13:08
  3. Retro-fitting HID Xenon conversion kit
    By anty in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2005, 06:55
  4. HID / Xenon
    By The Slug in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2005, 14:38
  5. Xenon Ballasts
    By NWMark in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th January 2005, 23:03
