EM TuningChris Nott
    Nov 2012
    16
    No power steering
    Guys please help,car has been running fine but for the last few days been a pain to start,only since the dark nights,this morning just about started drove to work with lights on,but when I finished work it would not start battery dead,so I carry a battery pack and it started no problem,But the power steering alarm on the dash came on and was like driving a tank home.
    When I got home and engine running I checked voltage at the battery to check alternator 14.5 volts,so decided to buy new battery,fitted battery car starts ok but still have steering warning lamp on dash.
    Any help appreciated
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    891
    Have you drove it after fitting the new battery?
    Growing old is mandatory, growing up is optional
    Nov 2012
    16
    Hi lee,yes took it or a run still the same
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    891
    Haaaa mine went of after i went for a run and turned some corners as i had the wheel off, was hoping be as simple as that for you.
    27,028
    You may need the faults clearing & then driving of, but the fact it hasn't gone maybe means it needs recalibrating with vcds.
    Ideally you need to ascertain if the new battery is also losing charge when standing or its ok now, before fixing the light.
    You need to check the battery draw when all is locked up & 30 minutes after locking to allow for all systems to shutdown fully.
  1. Power Steering Fluid
    By TrueNilbog in forum TT/TT-S/TT-RS Forum
    Last Post: 3rd October 2004, 02:24
  2. Power Steering Fluid Leaking A4 2.8 1997
    By bradmcw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2004, 12:53
  3. Noisy power steering?
    By GeorgieMcC in forum A8/S8 forum
    Last Post: 18th February 2004, 12:29
  4. V6 power steering
    By audiA3V6 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th February 2004, 18:34
  5. Power Steering Fluid
    By blued in forum General Technical / How To
    Last Post: 28th August 2003, 13:23
