Volks AutosSky Insurance
Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By Lewis583
Thread: 2.0 tfsi temp gauge low reading....
    Aug 2013
    Richmond
    20
    Hi, folks.... first post looking for a bit of advice, so go easy with me....
    I have an A3 2.0 tfsi (bwa engine) and the temp gauge is saying coolant is running about 70 degrees when on the move, but does
    climb back up to 90 when stood....
    once i'm up to speed again it will drop back to 70 (ish).
    temp gauge is reading correctly, as i have looked with vcds and an infra red temp reader and all say the same within a degree or so. Are there 2 temp senders or only 1 ?
    i have replaced the temp sender unit (green top/ 4 pin)and it is still reading the same as before, confirmed with vcds and infra red.
    so i am hazarding a guess at saying thermostat is stuck open...
    Vcds did say on measuring blocks that stat was 100%, as i'm new to these engines, i don't know if the stat is electrically operated or not....
    Or am i looking at a measurement that does not mean anything to this engine?
    If anyone has any ideas on this i would be grateful, as i have had a good hunt for info, but can't find anything conclusive...
    Many thanks, Phil.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    I can't give you a lot of help here mate...but i'm sure if the stat if stuck open then your fan will be on constant?
    Aug 2013
    Richmond
    20
    I would think if stat is stuck open allowing full flow then it will be underheating, not requiring fan.
    As opposed to overheating and needing fan to cool if flow was restricted....
    Unless i'm missing the obvious .....
    I shall wait to be shot down in flames!!
    then get my coat..........
    Thanks, Phil.
    Mar 2012
    369
    Agree - stat jammed open seems likely. I had this on a 1.8 petrol passat once with exactly the same symptoms. New stat cured it but I had to have two goes at it because they sold me the wrong one first time.
    Lewis583's Avatar
    Mar 2010
    870
    Had the exact same on my 20T (also a BWA). Replaced the stat which sorted it. The stat that was fitted to mine wasn't an electric thermostat and came complete with the housing, because you are unable to dismantle it.
    Not a particularly nice job as it's a bit fiddly.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Aug 2013
    Richmond
    20
    Cheers, Lewis and John.... I was thinking stat, but wondered about the electrically controlled stat as vcds was giving an engine outlet temp and radiator outlet temp... guess Lewis has cleared that one up for me!
    cheers.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,367
    This was one of the many problems found on my car.
    Thermostat stuck open and the engine running at 70C.
    Aug 2013
    Richmond
    20
    Cheers, Alex....... i reckon that confirms it!
    guess what ill be doing shortly...?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,367
    Quote Originally Posted by yorksphil View Post
    Maybe a trip to a tuner near you?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Thanks, Phil.
    No no, your right mate... stat jammed closed will be doing this... sounds as if it might be the stat.. only 1 way to find out
    Aug 2013
    Richmond
    20
    Hmm... possibly possibly, could do with a bit more grunt (previous toy an RS6 )
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    To agree with all the above just had this twice in a year! Once stuck open next stuck shut :-(
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Lewis583's Avatar
    Mar 2010
    870
    As luck would have it, I still have my old stat in my bedroom form a couple years ago. I don't know why I've still got it either
    The stat housing
    The actual thermostat
    The part number (06F 121 111 F)
    Note: yours may be different.
    When ordering the part give your reg/chassis number to them and they will sort which one you need. Not sure if an aftermarket item is available, but even if there is I would go with OEM. Best places to buy from are TPS or Audi main dealer.
    OVRA3 likes this.
    Full VCDS
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Can tell the colder weather is coming, not holding temp when moving is stat.
    Growing old is mandatory, growing up is optional
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,367
    You know what to do....and what a slippery slope it is....
    Aug 2013
    Richmond
    20
    Quote Originally Posted by Lewis583 View Post
    The stat housing
    Will stay with oem parts for sure! cheers for info....
    Aug 2013
    Richmond
    20
    Thanks for the replies folks!
    Quote Originally Posted by S3Alex View Post
    indeed, and a very steep slope at times!!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,367
    I know...just not sure what part of the slope I'm on at the moment!
    Aug 2013
    Richmond
    20
    stat in and running at 90 degrees, just in time for the coolish weather...
    Cheers for the advice folks....
    next problem, new thread.... boo hiss
    Feb 2014
    had a real big problem with temp too low on a golf gti v dsg 2.0 tfsi. changed the main thermostat and the problem persisted.
    turns out that the car has 3 thermostats.
    one "main" one, one for turbo, and one for transmission (dont know if manual has one)
    now the car gets to 90c degrees in 8 mins and stays there no matter what.
    Home Page Search Transmission Thermostat ES#382259 Transmission Cooler Thermostat - 4E0121113
    In line thermostat leading to the trans fluid cooler
    In order for your transmission fluid to warm itself to operating temperature under extreme cold conditions this thermostat may remain closed until coolant reaches a certain temperature. This thermostat is located in the main line leading to the transmission oil cooler assembly.
    s3joe's Avatar
    Mar 2012
    Liverpool
    296
    Visit s3joe's Instagram Channel
    This is a pig of a job
  1. a3 v6 - temp gauge not reading and fans not coming on
    By chrishil1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th May 2013, 18:02
  2. Coolant level warning, temp gauge reading 120c!!!!
    By Maz in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th October 2011, 13:37
  3. oil temp gauge not reading any ideas
    By pirate in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd June 2011, 20:12
  4. Bizarrely accurate temp gauge reading
    By A3Osprey in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th October 2009, 17:49
  5. temp gauge readings vag-com
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 6th February 2007, 17:01
