EM TuningJMB Retrofits
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By S3_Jacko
Thread: How many problems with DV valve after map ?
    Jun 2013
    326
    As above just getting a stage 1 map with cai and miltek in couple weeks just wondering how many of you has had to upgrade the DV valve ? If that's the correct part I'm thinking of as I had to upgrade my recirv valve on my Vxr after it was mapped as the standard rubber 1 was prone to tearing, I'm not great with cars so please bare with me if I'm confused I'm learning tho haha
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Mine had gone before the map. Worth checking an doing anyway as it's a cheap part. The newest is revision g... the d is a piston type but leaks as it has no diaphragm. I've not had any issues with the g since the map and I'm running 260bhp part number 06H 145 710 G
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    Same as above mine went at standard, just upgrade it now as a preventative measure! I've got decision D and not had a problem there is a lot more running this than the G I think
    Bullys3's Avatar
    Mar 2013
    Scarborough
    191
    Surprising how many people have got an audi s3 coming from the Vxr I've done the same never buy a vauxhall again
    turbonutz's Avatar
    Jul 2013
    Glasgow
    400
    well ive had running problems recently with my S3 which is mapped to stage one which ive resolved over past few days, had a shot on rolling road and diagnostic on friday ordered a revision D valve and replaced my revision G (which is older diaphragm one) which was totally deteriorated and had car back on rolling road today, totally different result!
    this is power to wheels, guy that ran dyno with me said to add on 40 odd for engine power, so would be running there abouts 305bhp (should maybe be bit more if ma exhaust wasnt blown and a maybe a crack on airbox)
    Grey line was first run with old totally f**ked valve and black was with replacement, some diffrence!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    The Forge and GFB diverter valves are worth a look,and of the two,the GFB may be a good choice for anyone starting to mod a car from new.
    GFB DV+ for late-model VAG 2.0T for Audi 2.0TFSI DTM EDITION
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,286
    Quote Originally Posted by S3Alex View Post
    Alex I was looking at that valve as i'm hoping to get my stage 1 done soon... is it worth fitting the valve 1st and run a couple of tanks of super juice to let your ecu build up some data before getting the file sent away for tweaking?
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    Quote Originally Posted by S3_Jacko View Post
    I don't think the valve alone should make a lot of difference,other than that you know it won't be leaking,or even likely to.
    I'd have the map and DV installed and the ECU will adapt over about a week's worth of running.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,286
    cheers mate... hoping to get it done in the next couple of weeks, looking forward to it
    S3Alex likes this.
    Jun 2013
    326
    Cheers guys just going to order the gfb DV this week and get it on may Aswel for the cost of £100 don't want a silly problem after my map
  1. How many people with stage 2 s3? Or running more than 350bhp
    By Sohrob in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2010, 13:36
  2. Whoops... problem with cooling system after accident
    By sebbelcher in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th December 2009, 23:25
  3. problem with my s3 after i lowered it?
    By mr-scriv in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th November 2008, 17:00
  4. How many owners with an uprated fuel pump?
    Last Post: 27th August 2008, 16:05
  5. problem with power gains after remap
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2006, 14:09
