Badger5EM Tuning
    A3 TDi S-Line
    Jun 2013
    Worthing
    MAF problem & Engine stutter when coasting. PLEASE HELP!!!
    Evening all,
    I'd really appreciate anyones help on this.
    I've owned my A3 2.0 TDi for a few months now. Engine managment light comes on, indicating Mass Air Flow Sensor problem. Took it to the garage, MAF Sensor not reading anything, now replaced. Drive the car for 2 days and kicks out a different error code (P0101 00257) which is still Air Flow related. Take it back to the garage and they say they can't solve the problem and I need to go to Audi which I'd rather not do!!
    I've heard of other mechanical faults causing the MAF codes to appear. Does anybody have any thoughts on this?
    Also, while I'm here, I get an engine stutter while coasting in Neutral, but not when the clutch is to the floor? Is this something to do with the clutch?
    I'd appreciate any help on this,
    Mike
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by money-mike View Post
    Evening all,
    Mike
    your car car is fitted with a clutch switch that dips the revs when the clutch is pushed to enable smoother changes I would also check all your earth points under the bonnet especially those behind the passenger headlight.
  1. Strange noise at low speeds and when idling... please help.
    By matt_s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th June 2010, 12:04
  2. Engine Emmision Light on, Please help
    By adamf200 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2010, 12:14
  3. Electrical problem with A3 1.6 2007, please help
    By jamieswales in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2010, 20:32
  4. Engine Just Cut Out. Please Help?
    By Ronniebiggs in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th September 2009, 23:03
  5. A3 1.8 T Sport sluggish when cold !! Please help
    By coopy in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2009, 12:10
