Volks AutosAH Fabrications
Results 1 to 8 of 8
    VAG_BADGER's Avatar
    Ricers in the rear view!
    Jan 2011
    Sheffield
    71
    2009 Stage 2+ S3 has wiring mods done on throttle body & MAP. Why?
    As per the title,
    My Audi S3 F/Lift is Stage 2+. It was bought this way and I've done little to it during ownership. I have just had the front off to upgrade the intercooler and noticed modifications had been done on the MAP sensor wiring & TB wiring? It has been done with the genuine VAG repair plugs so i'm unsure if the wires have been swapped about, could this be anything to do with the remap? Runs great and is a flying machine. No faults in any module etc etc. Just curious really?
    Thanks in advance,
    David
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Any pics of what's been done might be useful for those who know these things!
    Dec 2012
    231
    Could it of had WMI running on it thats been removed maybe?
    2010 Condor Grey S3 Sportback S-Tronic. 353bhp 400ft/lb.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Quote Originally Posted by H17YD L View Post
    WMI doesn't require any throttle body or MAP sensor alterations.
    Dec 2012
    231
    Oh I thought some WMI kits worked from the MAP sensor
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Usually at the ECU interface if you buy something like the Aquamist.
    Most of the others are boost pressure linked from the manifold.
    Dec 2012
    231
    That's it they have there own boost sensor, I thought they tapped into the MAP.
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,788
    Exactly.
    AEM's controller takes a tap from the manifold after the throttle body and measures boost directly,so there's no cutting into the wiring.
    The Aquamist system does take a feed from the MAP sensor,but should not require the TB or MAP sensor wiring to be cut about at the sensor end of the system.
  1. Another Joey Mod done today...
    By J7USS in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th June 2009, 13:53
  2. mods DONE in 07
    By chris_20 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th January 2008, 23:24
  3. How many miles has your motor done
    By peakey in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2008, 18:41
  4. Mods Done In 2007 & Todo In 2008
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th December 2007, 15:01
  5. tax disc holder has wires?
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2006, 13:16
Tags for this Thread
