Sky InsuranceBadger5
    Jul 2013
    21
    rough idle after new cambelt (-2.50 torsion value)
    Hey guys Bit of a tricky one here I've currently just taken my a3 To audi for a cambelt and ever since I've had a slightlt rough idle but my mpg has been really good at least 20% better than previously. I've checked the torsion value on vcds and its at -2.50 when warm is this within normal boundaries? The car has always been a bit difficult to start when warm also but that's been for years now. Any experts got any answers? I don't wanna phone Audi if its not a big problem lol.
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,763
    I would certainly ask them to double check the timing - it could have easily be a tooth out on the cambelt.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    -2.5 torsion needs adjusting. It should be between 0 to 0.5, once this is done the rear cam needs to be adjusted (position wise) to match, this will sort out the rough idle.
    Your MPG figures will be showing a lot better but won't have actually changed that much as the readings will be calculating based on your old sensor readings & cam positioning etc so in reality they won't be correct. You may have actually gained some MPG thanks to the cambelt change as this should have bought the valve timing back into line (rather than injection timing as the ECU controls that).
    The TDI's can be really sensitive to even the slightest adjustments. A .35 degrees adjustment on the inlet cam yielded me proven 4MPG improvement & much smoother throttle response too.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Jul 2013
    21
    Thanks for the response Max, I took it back to vw today and spoke to the "master tech" who assured me they changed the belt with a special cam locking tool pin, ( I already knew this) I then mentioned the torsion value showing -2.5 on vcds and the response I then got was that the cams aren't adjustable. I then replied yes they are he said no they are not I said yes they are..... After a few moments of who's right he agreed the pulleys where adjustable. He then offerd to check the timing and low and be hold he said it was perfect And that vcds is not proper vw diagnostic software, after feeling fobed off I feel I should pursuit this but don't know what the best option is, I can't force this dealership to fix my issue so my idea is to maybe take it to a competitor vw dealership and see what they say?
  1. Replies: 3
    Last Post: 13th April 2014, 23:30
  2. Rough Idle After Spirited Driving
    By JudderMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2013, 20:56
  3. Help A4 not idling after fitting new turbo
    By Davsinq in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2013, 21:22
  4. Blue smoke on idle after new exhaust
    By carld in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2013, 23:10
  5. Rough idle after cambelt change
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2005, 18:19
