JMB RetrofitsChris Nott
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By FOX1980
Thread: help locking bolt on wheel damaged
    Foxy
    Apr 2010
    147
    Hi all, as the title says im after some advice, I have a puncture and was going to put spare on only to discover the splines in the locking bolt itself are damaged so the key wont grip to turn, has anyone got a possible solution?. The key is fine and removes the locking bolts on the other three wheels.
    Thanks in advance
    DomH's Avatar
    Jun 2013
    Leeds
    116
    Do you have breakdown cover? They will come out and butcher it off
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by DomH View Post
    I had a missing key for my shogun I used a 1/4" drive socket and hammered it in to the bolt it made it form the shape and I was able to remove it .
    Foxy
    Apr 2010
    147
    Thanks for the replies will call my garage tomorrow to see what they can do, mine are genuine audi wheels nuts that came with the car
    27,099
    Quote Originally Posted by Chillout View Post
    +1 if all else fails, time to use a socket & a heavy hammer
    Foxy
    Apr 2010
    147
    do you mean hammer a socket over the external diameter of the locking bolt?
    Boon's Avatar
    Sep 2012
    South East Kent
    417
    Machine mart do a locking nut remover kit, they have a reverse self tapping thread inside so they grip, most decent garages should have some too
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    27,099
    Depends on the locking type fitted as they don't fit/work on some, as I tried myself, the outer protector metal ring stopped the extractor from getting a grip & just turned on itself.
    Apr 2013
    Aberdeenshire
    592
    I have irwin rounded bolt sockets but as above the outer sleeve stops this but sometimes you can rip it off I hammered the socket into the bolt it formed the shape of the key with bit of hard hammering then used it on all 4 wheels.
    Foxy
    Apr 2010
    147
    the bolts are the standard ones and they do appear to have a ring around the inner part
    Foxy
    Apr 2010
    147
    Managed to remove the nut by parking close to my house and using a jack to hold the breaker bar on the nut and turn
    NHN likes this.
    27,099
    Now that is thinking outside the box, well done that man
    Foxy
    Apr 2010
    147
    Thanks mate, thanks also for everyones advice.
  1. TTRS WHEEL - DAMAGE - HELP HELP PLEASE!!!
    By Chris Coates in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2013, 07:11
  2. locking wheel bolts for wheels with spacers
    By solaris in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd April 2011, 20:54
  3. S3 2009 Wheel locking Bolts
    By Dave1000 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2009, 22:20
  4. Anyone with Extended wheel locking bolts.
    By amoani in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th March 2007, 21:45
  5. Help needed with car accident damage.....
    By imported_spuddie007 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2005, 13:01
