Badger5EM Tuning
    Dec 2012
    24
    RNS-E, mind of its own!!!
    Hi there wondering if any of you could kindly help me out, got an rns-e fitted in my 2007 s3 (came with car) but every now and again it has a hissy fit, the screen unfolds when you unlock the car, start the car try put it back up and it goes up but then imediatley comes down again, try putting it up again same happens etc etc,
    some times it will eventually go up on its own and stay as it should, but then the next time i use the car it starts all over again,
    ive tried having a search but cant find any topic specific to my problem, just threads on the fitting of the rns-e
    if anyone can shed some light onto helping me fix this rather annoying issue that would be great,
    Many Thanks Phil
    27,120
    Could be firmware problem, best to reflash with fw to see if it fixes this issue.
    Also could be the folding mechanics being faulty or pcb, for this its an unknown tbh & requires you to spend some time on to resolve, no doubt vcds will be needed aswell as firmware dvd.
    Why not upgrade to the mk2
    Dec 2012
    24
    Thanks for your help, i best do a bit of research on reflashing and how to go about it, not too clued up on the audi stuff used to my old evo where you couldnt hear the stereo anyway, lol
    is it a plug and play for the mk2? does that have a decent postcode entry on the sat nav?
    27,120
    Nav is the same, better screen, sdhc slots, ami compatibility, quicker cpu.
    I always advise to code it & it is a direct swap for your existing rns-e.
  1. 2.5TDi Temp gauge has mind of its' own!!
    By tonycaterham123 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2009, 18:08
  2. Concert with a mind of its own!!!
    By alibob in forum In-Car Entertainment
    Last Post: 27th February 2007, 14:00
  3. Sunroof has a mind of its own
    By adamgroves in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2004, 19:57
  4. Petrol gauge has a mind of its own
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2004, 10:37
  5. My clock has a mind of its own
    By Kevint in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:52
