Badger5EM Tuning
Results 1 to 8 of 8
    A3 SportBack 2TFSI quattro DSG
    Jul 2009
    Norway
    226
    GFB DV+ diverter valve kit
    Hi guys
    A while back I stumbled upon this. Not sure if it has been written about here, so I am putting it up for you.
    The product info can be read here
    http://www.gfb.com.au/dv-plus-divert...o-applications
    I have bought it my self and it works. I had the old G version DV running on K04 APR setup. The stock DV work ok but was leaking and made a lot of sound.
    this baby does make the system sealed and no sound is released and I am having the Carbonio intake.
    There has been made two editions to this DV+ valve. Make sure to get the rev. Version with new spring.
    You can read more in my thread started at golfmk6.com forum. (More info on the TSI engine then here)
    GFB DV+ Diverter Valve Kit - anyone tested this? - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    You can buy it here.
    GFB DV+ Diverter Valve Kit - 2.0 TFSI/2.0TSI - A3 (8P) - Audi - Shop By Car
    Now go out and buy it. You've never have DV problems ever.
    PS. The OEM rev. Piston DV leaks too.
    Best regards
    J$B
    Norway
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    I don't see how the rev g leaks unless it's torn? It has a diaphragm so shouldn't leak. Correct me if I am wrong
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Jul 2009
    Norway
    226
    They all leaks at the contact points. Not on the valve it self. So i have heard / read / understand.
    So if you are running the "G" model like me and the diaphragm is not ruptured it will leak. The same will the piston style to.
    This is due to high or higher pressure and the DV will give inn.
    If you read the thread I have linked in you'll understand more.
    Best regards
    J$B
    Norway
    Jul 2009
    Norway
    226
    There is a video showing the piston type leaking by just blowing on it. See page 4 and thread #79 in the attached link.
    GFB DV+ Diverter Valve Kit - anyone tested this? - Page 4 - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    The thread has been watched over 14.000 times in a short time. This is the real thing guys. I installed mine yesterday and the car feels more snappy (Les lag) and my but dyno is telling me more power.
    Best regards
    J$B
    Norway
    May 2013
    London
    52
    AMD started stocking these a few months ago. I had one fitted just as mine was starting to rupture. No complaints to date
    May 2013
    London
    52
    Jul 2009
    Norway
    226
    Geforce189 you are right. The Rev.1 came out a few month back. The rev.2 cam 2 weeks ago.
    Call AMD to ship you the new spring. It's it important for holding the boost.
    It is a free upgrade.
    Best regards
    J$B
    Norway
    May 2013
    London
    52
    Nice! Thanks for the tip off! Will do...
  1. AMD Diverter Valve Service Kits??
    By A3 T in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2011, 08:22
  2. S3 induction kit and dump valve or diverter valve
    By brough74 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2010, 10:09
  3. Hose kit and diverter valve
    By Shug1874 in forum DPM Performance
    Last Post: 16th October 2008, 16:29
  4. what diverter valve kit
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 17:24
  5. Diesel Diverter Valves
    By simmolee in forum Diesel forum
    Last Post: 10th April 2003, 17:22
