Chris NottJMB Retrofits
    Sep 2013
    London
    62
    R32 310mm Rear Brake Conversion on Tdi
    Do i just need the calipers with carriers. brake discs and backing plate for r32 brakes to go on? Anything else
    tdi-man's Avatar
    Jul 2009
    1,612
    yes you do as I have done it
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Sep 2013
    London
    62
    I'm planning on doing R32 fronts aswell but my rear's are so bad now. Had a advisory on rear discs last mot and its 4 months later. Will it be a bad thing to do the r32 Rear's and then do fronts another time.
    tdi-man's Avatar
    Jul 2009
    1,612
    well I did my fronts first and then the rears a few months later
  1. AUDI S3 / MK5 R32 / Leon Cupra Calipers & Disk Kit / Set 334mm Front & 310mm Rear
    By DOLPHIN DIESEL in forum For Sale/Wanted - Audi Parts
    Last Post: 26th April 2012, 08:36
  2. NEW Golf Mk5 R32 / Audi S3 Front and Rear Brakes - 345mm Front and 310mm Vented Rear
    Last Post: 16th August 2011, 14:13
  3. Rear brake upgrade b5 a4 2.5 tdi quattro
    By adamss24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2009, 11:55
  4. 140PS TDI rear brakes?
    By sprout99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th May 2008, 21:13
  5. Rear brake problems on Altea TDi Sport DSG
    By loadswine in forum Other Brands & Models
    Last Post: 17th February 2006, 19:29
