Volks AutosAH Fabrications
    Apr 2010
    182
    A3 2.0 TDI temp sensor replacement (fans staying on)
    Hi all, having a problem with my girlfriend 2.0TDI 140 A3, the fans are staying on when the engine is running. last time it did this i think i replaced a coolant sensor on the right hand side of the engine near the air box? i know i didnt have to replace the fans or anything. iv had a look through as many old threads as i can find but still cant find the part No for the sensor. Is anyone able to point me in the right direction of it?
    Dan
    26,722
    There are 2 sensors on the bkd engine, possibly other engine codes aswell, 1 on the side like you've done & 1 hidden in the front in between coolant hoses to the left of the IMF.
    Apr 2013
    Aberdeenshire
    580
    Scan it as it could be the fans at fault I think the control module is integrated into one of the fans.
    Jun 2010
    65
    Quote Originally Posted by Chillout View Post
    I had a similar problem, my fan wouldn't cut out even with the engine off! The only way it would stop was to disconnect the battery or the plug on the fan module. Anyway, it happened few times, the first few times were solved by topping up the coolant. The last time I had to replace the whole fan unit. Cost me about £70 from ebay and about £30 for someone to fit it.
  1. coolant temp sensor replacement
    By scott13 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2011, 15:33
  2. 2.0 TDI Temp sensor change, help needed please
    By tommy18 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2010, 17:21
  3. Temp Sensor 2.0 TDi BKD
    By Gti Jazz Blue in forum General Technical / How To
    Last Post: 19th May 2008, 09:24
  4. Coolant Temp sensor - TDi
    By sprout99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2007, 12:19
  5. temp sensor passat tdi
    By vw754 in forum Volkswagen and other VAG
    Last Post: 25th December 2006, 21:51
