Chris NottEM Tuning
Results 1 to 7 of 7
    Feb 2011
    Leeds
    58
    2.0 TDI trouble starting when warm?!
    Hello Guys,
    Bought my 2009 8p3 back in April and a few months ago started to notice an issue starting when warm. Basically after a long run 40-50 miles+ so oil etc is fully warmed I park up, go shopping or fill up, come back out and it wont start! It turns over once even if I hold key on stage 3 it just doesn't do anything. It can then take a further 5-10 goes to start up, it is as if it is not catching.
    This only happens when engine is warm, starts first time on a morning. I have taken it into Leeds Audi under warranty and after 1 week of having it, they cant see any fault codes and are trying to fob me off with a new battery?? I have videos that I have shown them and despite them being the dealer they don't seem to have a clue...
    This is very embarrassing as I am sure you can imagine, the car only has 60k so would have thought the battery would be in order, more likely to be something else they just don't seem bothered.
    Any suggestions or pointers would be really helpful, I am going to ring round a few indies tomorrow and run it by them, they can probably tell me straight away!!
    To really rub salt into the wound the courtesy car I they have given me is a TT TFSI!
    Cheers!
    Si
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by Simon16 View Post
    Hello Guys,
    Cheers!
    Si
    possibly your coolant temp sensor ,you could request some one graph it wit vcds and see what it's hot reading is I can't see it being the battery if it only happens with a hot engine that said it wouldn't do any harm to have the battery tested or when it won't start connect to another car as if jump starting obviously not at a filling station though !
    oh also cam and crank sensor can play up with heat.
    Feb 2013
    Grimsby
    1,101
    think its the starter motor, i do believe its a common problem not to work on hot startup. This is only what iv read from these forums and i think i remember seeing it. but im sure someone will correct me xD
    JJ.
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by JJ.Foulds View Post
    JJ.
    Heard of that too but it seems odd to me though .
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    It would seem to be the good old hot start, starter motor issue, but rare to see it in a later 09 car.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Feb 2011
    Leeds
    58
    Thanks a lot for the replies guys, I was going to say I was struggling to find it on cars as new as mine when I was searching. Gonna ring Leeds Audi and have a little chat! Cheers
    Simon
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    On older TDI's (PDs) this is a known issue.
    To fix this problem there is a remap that should be available at any dealer or tuner. Also the battery and starter motor should be checked.
    I've had this problem with my car too. I've done all 3 thing. Started with the battery than remap and eventually the starter motor.
    No more problems now.
    Although, as mjr901 said, this is common to the older PD engines. You are the first I read about having this problem.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
  1. A6 2000 2.7t - won't start when engine semi warm
    By dan small in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd October 2013, 09:57
  2. S4 problems starting when warm
    By SonicDeathmonkey in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th January 2010, 14:52
  3. ECU Engine temp sensor - difficult start when warm
    By James09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 19:52
  4. Starting when warm - help
    By Morzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2009, 16:48
  5. Occasional high rever when starting from warm
    By nlldavies in forum Diesel forum
    Last Post: 15th July 2007, 20:46
