Volks AutosJMB Retrofits
Results 1 to 8 of 8
    Aug 2013
    Norfolk
    67
    wiring head unit to standard sub and amp
    I've just got a new head unit. After fitting it The rear speakers don't work and neither does the sub. Is therea way to wire them to the new hu.
    I knowi might get told ditch the amp and sub and get a better one but money is tight so I can't afford it right now.
    27,114
    Sounds like you havnt connected the amp feed wire to enable it for rears, go & check your wiring.
    Aug 2013
    Norfolk
    67
    Which one is the amp wire? Sorry I've never done this before
    Mar 2012
    369
    Quote Originally Posted by joe_echo View Post
    You don't (unless I missed it) say what year the car is, but the best clue is on the top of the factory head unit -there's usually a sticker on there that shows each socket on the back and what the pin outs are. If yours is 2003 - about 2006/7 it'll have two 8 way ISO connectors - one is for power and earth, the other's to the front speakers. There's a third mini-ISO connector (longer and narrower with more pins - that has the connections for the amp. You need to wire the pre-outs from your new head unit into there - there's a range of adapter looms available or you can make your own if you're handy of course.
    Aug 2013
    Norfolk
    67
    oops sorry its the 2000 model. I have two iso cables, a red connector with only one wire in and a collection of small connectors all joined together. I will have a look at the onld one tonight and also post some pictures up.
    27,114
    That's an 8L not 8P so wrong section, although wiring is close to the same.
    Aug 2013
    Norfolk
    67
    any chance one of the mods can move this to the 8l section. I must have clicked 8p by mistake.
    Jul 2013
    Uckfield
    112
    Follow fanta On Twitter Add fanta on Facebook Add fanta on Google+ Visit fanta's Youtube Channel Visit fanta's Instagram Channel
    To help anyone new coming to this thread, the info here helped solve my issue: http://www.nexxia.co.uk/products.asp...fied%20Harness
    It explains where the spare cables go.
  1. Sub And Amp Wiring Issue.
    By N.Singh in forum In-Car Entertainment
    Last Post: 26th January 2012, 09:38
  2. Replies: 2
    Last Post: 16th October 2011, 12:30
  3. Adding a sub and amp to standard HU.
    By baz za in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd December 2010, 23:16
  4. Sub and Amp - Wiring
    By iyrix in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th May 2010, 16:43
  5. Connecting aftermarket sub and amp to my factory head unit
    By m_ozzy_h in forum In-Car Entertainment
    Last Post: 5th February 2009, 10:09
