AH FabricationsEM Tuning
Thread: Vagcom help
    Jul 2013
    311
    Vagcom help
    Hi guys just scanned my car and I have the fault code 000051 turbo bypass clave which comes back with nothing on ross tech wiki !! Fault won't clear it comes back in even when not running so I'm thinking possibly a duff dv ?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Sometimes if non-genuine cables are used, fault codes like this can occur.
    Jul 2013
    311
    Never had problems in the past with my cable it seems like the real thing black one not a blue eBay special
    ruairi83's Avatar
    Dec 2007
    739
    If you can update vcds with cable and paid £260 then it's real cable and you will have support fr free from Ross tech so can email them. if you can't update vcds and cable is black and bought off vag diagnostics then it's a fake and have no support.
    ross tech have all the faults.
    27,072
    Quote Originally Posted by s3_sid View Post
    What version VCDS are you using?
  1. VAGCOM Help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2008, 21:35
  2. 2008 S3 Vagcom help
    By Oli. in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2008, 17:07
  3. Haldex controll module leasking??? vagcom...help please
    By scott_johnson in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th February 2008, 21:26
  4. vagcom help
    By quattrov6tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th November 2007, 20:50
