AH FabricationsJMB Retrofits
Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By TDI140
  • 1 Post By Sayam
  • 3 Post By smurfworth
Thread: Tdi BKD Intake hose developed let me know what you think
    TDI140's Avatar
    May 2011
    1,329
    TDI BKD hose developed,let me know what you think
    silicone made its thick 4ply silicone material very strong and much bigger than the flimsy standard plastic hose, fits BKD engine not sure about the pd170 if the intake hose is the same then it will fit
    thanks
    tdi-man likes this.
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Feb 2012
    322
    please forgive my ignorance but what benefit would this bring? Or is it purely for looks?
    NHN likes this.
    May 2013
    7
    As above comment, having a small section like this fitted just looks odd detracts rather than adds.
    TDI140's Avatar
    May 2011
    1,329
    It looks good but also the standard one has split a 3 times for me now so decided to have one made, also this is much larger than the original plastic hose so more air passes through but mainly had it developed so i dont have to keep buying new plastic ones as there £39 black ones are available as well, there a better design to the darkside developments ones
    27,033
    If yours has split several times, then I can understand the reasoning for getting this, but for anyone that hasn't had split oem plastics as per myself on 2 cars, I'd say its a waste of money IMHO, it wont make any difference to power at all, as it still has the same feed & onward size connections, its no different interms of fitment & diameter tbh.
    Also saying its not a sales pitch then telling everyone a price & colours available in, is a bit contradictory fella, if its an item that's going to be for sale in various guises & quantities, then the seller would need to be a sponsor to offer these things unless its a once only group buy, of which it doesn't appear to be, you need to make it clear whose selling these & the setup, so admin can look at this picture.
    Feb 2011
    Plymouth
    1,117
    Pretty sure you've already posted this before, then you had the same comments as above and you deleted the thread.
    waste of time unless you develop the pipe all the way to the inlet of the turbo. Plus your clamping plastic pipes with a mikalor clamp, which is made for EXHAUSTS and that probably doesn't help with cracking plastic pipes.
    If it was needed it would have been developed by now.
    NHN, martinivw and Rhyso like this.
    27,033
    I do wonder, have you checked your mounts for play, as the flexy would only realistically be stretched/crack if mounts were worn a fair bit & it allowed the flexy to, well basically flex allot more.
    The other cause of the flex becoming holy, as such, is the tandem pump/lines clips, to the left of the intake/maf area, it catches the flexy & creates a hole, but nothing detrimental to cause problems as such IMHO.
    TDI140's Avatar
    May 2011
    1,329
    Mounts are all fine so is tandem pump lines, when you move it it just splits so silicone is a way to improve this
    TDI140's Avatar
    May 2011
    1,329
    Quote Originally Posted by smurfworth View Post
    clamps don't need to be so tight thats the plastic cracks mate, also dark side developments but a silicone bend on there intake pipe soit must be for a reason mate
    2.0 TDi BKD (PD140) Airbox to TIP Silicone Hose - Darkside Developments
    27,033
    Quote Originally Posted by TDI140 View Post
    Not really, the silicone doesn't have the play in it which is needed for that joint, hence the flexy parts & if yours is cracking time after time, then you do have an issue there, as these are not prone to cracking unless they're under undue stress.
    TDI140's Avatar
    May 2011
    1,329
    Not sure pal ive bought 3 now so it could be down to when i clean the air filter maybe it moves around but i rang darkside up and they say the flexy plastic is a let down and cracks so the silicone one is much better and they know the BKD probably best out of everyone
    Feb 2011
    Plymouth
    1,117
    I wasn't aware of the dark side one, anyway dark side one looks much better and is cheaper.
    Thats all I can say tbh, but I don't believe I will ever be purchasing one of these pointless things either from yourself or darkside no matter what it looks like.
    Aug 2012
    68
    What about something like this if it would fit?
    TDI140's Avatar
    May 2011
    1,329
    no one is forcing you
    open cone filter was the next step im just trying to find a decent open cone filter and then hopefully make some sort of heat sheild as well
  1. Just want to know what you guys think of what i bought??
    By nath-w in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th May 2010, 08:31
  2. My Audi A3 8L pics let me know what you think?
    By mk1kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2010, 17:25
  3. anyone know what an N75 valve is on a TDI engine?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2006, 22:25
  4. Samco Intake hose Problem
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 20:12
  5. Air Intake Hose 68
    By AndyS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th September 2003, 22:32
