Chris NottVolks Autos
Results 1 to 15 of 15
Thread: Alarm problem
    Feb 2012
    124
    Alarm problem
    I've got a audi a3 2.0 tdi 53 plate. Every few times I lock my car, the alarm will start beeping constantly for around 10 minutes. I've tried opening and closing the doors, boot, bonnet and holding the key fobs down but nothing seems to turn it off, I had the car on a vagcom this morning and the faults are reading - 0597 Alarm Horn fault, has anyone had this problem? Can anyone help please?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    batterys are ****ed in the siren
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,183
    Visit leeds2592's Instagram Channel
    Tried clearing the code via VCDS and seeing if it comes back?
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Feb 2012
    124
    I tried to clear it and happened again when I got home and locked it,
    Feb 2012
    124
    Bez101 how do I resolve this problem, new alarm siren?
    bez101's Avatar
    Jul 2008
    8,530
    either new second hand
    or remove take apart and if alls good inside then theres a mod to replace the batteries
    have a search on here theres a guide knocking around
    Feb 2012
    124
    I've found one on ebay, is this what I want?
    http://item.mobileweb.ebay.co.uk/vie...d=251312646168
    bez101's Avatar
    Jul 2008
    8,530
    remove your one first
    check its causeing the problem
    then get part number from old unit
    Feb 2012
    124
    Where abouts on the car is it? And how will i know if its broke?
    27,121
    Drivers wheel arch right up behind the wing/liner, its in a fecker of a location, I suggest buying new as 2nd user ones will have more chance of going wrong quicker & maybe ask audi to change it over.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,292
    I had this problem with my S3 about a month ago... after investigation I found out that the rear washer hose had came loose and soaked the boot button electrical terminals... a bit of wd40 and no more problems and happy neighbours!
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    4 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication - Intermittent
    01134 - Alarm Horn (H12)
    00956 - Key 2
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    000 - -
    That is the fault I was getting when I had this
    H12 backup alarm horn problem
    S3 1.8t Ming blue with ivory leather & 18"tt alloys
    Feb 2012
    124
    Thanks for the help guys, yesterday I removed my wheel and wheel arch lining on the front drivers side of my car and I could only see a metal box, is this what the alarm horn is in? If yes how do you get the alarm horn out, couldn't see any screws or bolts
    shariain's Avatar
    May 2004
    Glasgow
    1,173
    That's it in the box. The box is riveted on to the inner wing. I just bent and manipulated it using the rivet as a pivot point then removed the alarm box which is plug and play then just reversed my process as I didn't have a rivet gun to hand to replace it if I took it out.
    Feb 2012
    124
    Cheers mate, I'll have a go on monday when I'm free! I'll let you know how I got on!
  1. Alarm problem
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2005, 15:25
  2. Further twists to my alarm problem
    By FactionOne in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 14:02
  3. S3 Alarm Problem...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th August 2004, 12:27
  4. arggggg! A3T alarm problems :(
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th July 2004, 10:52
  5. ALARM PROBLEM
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th July 2004, 19:41
