JMB RetrofitsEM Tuning
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    Coilover Help: What are these?
    I've had very squeaky rear Bilstein PSS10 coilovers for a while and just now, I pulled the rear wheels off and had a look.
    Upon removing the blue guillotine sleeve (pulling it down), I noticed these broken yellow foam sleeves.
    The RHS has both broken, the LHS has just one broken.
    Can anyone tell me if these come with the Bilstein PSS10 coilover kit or have they been added on by my installer (I purchased second hand)?
    RHS
    LHS
    I put these sleeves back on and taped them together again.
    After apply silicone spray to all my bushings and spring joins, etc, i took the car for a drive and my noise has pretty much gone away, comes back on the odd occasion.
    I'm wondering if these broken sleeves are the cause of my noise?
    I guess time will tell as the silicone will eventually wear off so i will see if the noise comes back.
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    Nov 2011
    69
    I think they would have come with the kit as the standard shocks have some but are a different size.
    Feb 2004
    Borders, Scotland
    404
    Look like bump stops to me, don't know much about the coilover kit you're talking about though but they look the same as the ones on standard suspension ones which degrade over time, causing the cover to drop down, then water/dirt gets into the shox and knackers them, happy days!
    Feb 2011
    Plymouth
    1,113
    That's the bumpstops, but to be honest, considering the height you have your coilovers set at you won't exactly need them.
    poli84's Avatar
    Nov 2010
    430
    Thanks guys, makes complete sense these are bump stops.
    Also makes sense that they would be broken given the car used to sit lower and on some spirited drives, I've hit full bump at speed which would cause them to break.
    Given they are bump stops, they certainly would not be the cause of my squeaking rear suspension which means it must have been the silicone application to everything which has stopped the squeaking.
    REVO Stage 2+ /
    Bilstein PSS10
    BUILD THREAD
  1. Help with my bluetooth? what are these wires?
    By marnie2k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2011, 21:19
  2. What are these rims??? Please help!
    By Technik in forum Handling
    Last Post: 20th September 2008, 13:55
  3. What are these calipers from ???
    By noslojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2005, 22:02
  4. what are these wheels from?
    By SQ_lover in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th April 2005, 20:59
  5. Passenger seat - what are these metal things...?
    By skempster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2005, 17:27
