Monster MotorsportChris Nott
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By bosun
Thread: HELP!! A3 Quattro 170 TDI '07' Rear Shock???
    Jun 2013
    17
    Been searching through the forum and cant seem to find any answers about an OEM replament or part numbers.
    Car failed MOT because of a broken shock and I need to get them fitted ASAP. Bought these from GSF and the guy went to the back to look on a dealer computer to see if they were right for an S Line.
    REAR COIL SPRING 511VG1380
    Thanks People
    Nick
    Jun 2013
    17
    Just to update spoke to Audi today and they gave me a price of around £80 incl Vat.
    Part number 8P0511115BL
    Audi - A3 - 2005 - Rear axle - coil spring3 paint marks 1 FARBSTRICHE (8P0511115BL) Teilekatalog (Pats Catalog)
    gen.heinz guderian likes this.
    Feb 2004
    Borders, Scotland
    371
    Your old springs should have colour codes on them, maybe a green dot followed by 3 grey dots (my S-Line 140TDI quattro). Dealer shoud be able to match them from this alone. Not sure about cheaper replacements, some of these companies don't understand, standard/Sport/S-Line/ S3 etc. My Wife has a 170 so I could check that if you want but even though they are the same car it coule be different. Also depends what height you want it to sit, I have just gone for S3 springs which are -35mm, same as the H&R upgrades. S-Line is -25mm incidentally, why am I so knowledgeable, well I asked questions and did various searches on here.
    Jun 2013
    17
    Another update...
    Just ordered these Audi A3 2.0 TDi Quattro Mk2 Lowering Springs Apex 30mm
    Audi A3 2.0 TDi Quattro Mk2 Lowering Springs Apex 30mm | eBay
    Asked for next day which bumped the price up to £124. After much searching of here and the TT forum I know that the S-Line is 25mm lower than the standard, so these will drop my car by only 5mm hardly noticeable. I'll get them in tomorrow and report back.
    Feb 2004
    Borders, Scotland
    371
    Be interested to know how you get on, I was tempted by lots of things, these included, I don;t think anyone's got anything particularly bad to say about them so they may just be the thing to have.
    Jun 2013
    17
    Quote Originally Posted by Vorshprungdork View Post
    Well just my luck, fitted the springs and the drop is a lot more than just 30mm...
    What has happened... I've got 18's on and only about 10mm of the tire showing And hardly any movement... Me sitting on the boot lip @17st and limited bouce
    Help
    Feb 2004
    Borders, Scotland
    371
    What do you mean 10mm of tyre showing, arch gap 10mm?
    Jun 2013
    17
    I'll pop the photo up
    Jun 2013
    17
    http://sdrv.ms/16u2KfG
    There you go... Backs with springs, fronts normal
    Look at here >>>> Who has 30mm Apex springs fitted to there S3?
    That's 30mm?!?!?
    Feb 2004
    Borders, Scotland
    371
    OOh that is low at the back particularly, my S3 spings are -35mm and aren't that low, could be on the bump stops which would explain why it's solid. You can cut them but wouldn't have thought with a 30mm drop you would need to, I didn't.
    Jun 2013
    17
    I know. Read up about them before fitting. Although I haven't found a picture of an A3 with just the Apex coils on. That S3 was the closest I found
    Feb 2004
    Borders, Scotland
    371
    Did you keep the top and bottom spring seats, the rubber bits? I boght new ones for mine, olds were quite compressed under the pressure of the springs for years, so new ones would probably make it sit a bit higher.
  1. DPF Delete for a 170 TDI Quattro Help?
    By MOOSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2011, 18:42
  2. 2007 a3 quattro 170 tdi high idle loss of power help needed
    By gixer600 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2011, 15:37
  3. S-Line 170 TDI or Sport 170 Quattro
    By Davidb67 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd October 2007, 09:02
  4. 2001 1.8T Quattro Sport Rear Shocks
    By mtaylor55 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2007, 21:05
  5. New A4 tdi Quattro 170 phone kit
    By gradwells in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2006, 15:13
