Chris NottBadger5
    kaliber's Avatar
    kaliber
    Sep 2009
    harrow
    26
    need help, coolant leak. audi 1.6 fsi
    hi guys,
    in the last week my coolant level warning came on, didn't think much of and refilled it. its now happened again and I've noticed a small puddle of coolant coming from the exhaust.
    does this definitely mean I have a cracked head, or could there be any other minor repair that is at fault.
    its a 2005 a3 1.6 fsi sport btw.
    this is my worst nightmare. ((( absolutely gutted
    thanks in advance
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by kaliber View Post
    hi guys,
    thanks in advance
    Are you sure its coolant or could it just be moisture produced by the cat ?
    kaliber's Avatar
    kaliber
    Sep 2009
    harrow
    26
    99% sure its coolant mate.
    anyone heard of this issue on a 1.6 before.
    and how much am I looking at to repair??
    Mar 2012
    369
    I haven't heard of it on 1.6 FSI before (I have an interest though as I have the same car)
    It could be the head gasket rather than a cracked head or block - but in either case, the head would have to come off.
    If you're wrong about the coolant in the exhaust, it could be a cracked pipe or thermostat housing according to these -
    Fsi expansion tank
    Over Heating A2 1.6 FSI
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by JohnE View Post
    Fsi expansion tank
    To find the source of the leak you would need to have the system pressure tested if you can't find it visually.
    That said I think your egr is liquid cooled so it could also cause this you could remove it and see if it has coolant staining or if your level drops when not running bypass it and see if it holds water overnight.
  1. Help! Coolant Leak
    By WorkInProgress in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2013, 12:21
  2. Help! coolant leak after doing head gasket
    By neilmeagher in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th September 2011, 22:05
  3. Newbie needs help - coolant fan issue
    By gnat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th June 2011, 12:46
  4. Need help from you audi brainers gearbox
    By lewigiepops in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th August 2009, 21:56
  5. Need Help finding 1978 Audi 80 B1 Club in England
    By tonyaudi80 in forum Classic Audi Forum
    Last Post: 2nd February 2009, 16:53
