Like Tree1Likes
  • 1 Post By Chillout
Thread: Help identifying this noise
    Sep 2007
    26
    S3 with just over 40k on, recently had a service + cam belt change but this noise was happening before.
    A local independent doesn't know what it is, any ideas before I take it to the stealers?
    https://dl.dropboxusercontent.com/u/...%2054%2007.mov
    It's more noticeable towards the end after switching off the engine.
    Any help appreciated
    3.2 V6 Quattro S-Line DSG
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by chrisred View Post
    Sounds like your pcv unless it's your aux belt I would go pcv
    chrisred likes this.
    Sep 2007
    26
    Quote Originally Posted by Chillout View Post
    Thanks for your reply. It seems to happen more once the car is warmed up, is more obvious when decelerating / coming to a standstill and mostly seems to happen when turning off the ignition after using the car for a while.
    After Googling a bit more I can't find any videos showing the same noise but plenty pointing to similar issues so will give it a try, Cheers!
    Sep 2007
    26
    So the dealers want £140 per hour for investigation and the same again for repair, so am looking at £300 before I've even started for a niggle (it's a bit noisy but doesn't seem to be affecting performance currently)
    I've uploaded another video, note the 3 clicks after the whining noise finishes? This also happens quite often so am wondering does this also point to the PCV being faulty?
    https://www.dropbox.com/s/5f7b4m8agur3by8/IMG_1500.MOV
    I've put it into a (non audi) Indie who couldn't resolve the issue at the same time as the service/cam but if it's likely the PCV I could ask them to go ahead and replace it.
    Any help appreciated.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    I'd guess the whining is a pressure leak whistle, and the 3 clicks are over run (timing\fuel issue caused by the pressure leak - maybe the turbo manifold gasket). £300 is too steep & I'd have thought any Indy worth using would be able to find & fix the fault without too much difficulty! A 2ft piece of garden hose makes a great stethoscope.
    Try taking it to someone else. Where are you located?
    2009 A3 SB 2.0T DSG S line
  1. HELP!! What is this noise?
    By Quattro180 in forum Diesel forum
    Last Post: 1st February 2012, 13:14
  2. Help identifying this connector please
    By baynesey in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2011, 11:05
  3. Anybody please help me identify this?
    By Nessy in forum Classic Audi Forum
    Last Post: 3rd January 2007, 20:44
  4. Whats making this noise ? HELP !
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2006, 18:44
  5. please help. is this noise from suspension ?????
    By anwar in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st October 2003, 21:19
