Help with error code
amit91987
Member
South West London
Hello
I scanned my car with VCD and have attained the following error code which can explain why I have been getting weird clicking/knocking noises after the fan belt was changed.
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
RPM: 1050 /min
Torque: 14.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000111
Torque: 146.0 Nm
Torque: 0.0 Nm
Readiness: 1 2 0 0 0
Please would anyone be able to advise on what this could be?
Hello
Freeze Frame:
RPM: 1050 /min
Torque: 14.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 11000111
Torque: 146.0 Nm
Torque: 0.0 Nm
It could be the fuse or the intake actuator itself sometime the teeth break that could be the clicking you hear I would check the fuse and if its ok I would remove the cover and check the teeth on the gear.
also your battery voltage looks a bit low
Not sure what fuse as I have a 3.2 but if you google vw or audi v157 you will see issues of broken gears but I would check as much as possible before pulling it to bits as it could even just be dirty.
found this its on a passat but I would think the fuse layout would be similar.
2.0 gt tdi problem
Hi I have tried looking at the fuses but they look completely different to the layout in the owner's manual and of the link provided earlier. Here is a photo I took earlier.
673
7K
