Chris NottBadger5
    amit91987's Avatar
    Nov 2010
    South West London
    101
    Visit amit91987's Instagram Channel
    Unhappy Help with error code
    Hello
    I scanned my car with VCD and have attained the following error code which can explain why I have been getting weird clicking/knocking noises after the fan belt was changed.
    19559 - Motor for Intake Manifold Flap (V157)
    P3103 - 000 - Malfunction
    Freeze Frame:
    RPM: 1050 /min
    Torque: 14.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.78 V
    Bin. Bits: 11000111
    Torque: 146.0 Nm
    Torque: 0.0 Nm
    Readiness: 1 2 0 0 0
    Please would anyone be able to advise on what this could be?
    19" speedlines, S3 rear, LED tail lights, Votex Spoiler, Bi- Xenons, Auto lights, Cree Led fog lights, Eibach Sportlines, Tints, Pioneer HU, Reverse Camera, Carbon fibre trims, LED interior lights
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by amit91987 View Post
    Hello
    Freeze Frame:
    RPM: 1050 /min
    Torque: 14.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.78 V
    Bin. Bits: 11000111
    Torque: 146.0 Nm
    Torque: 0.0 Nm
    It could be the fuse or the intake actuator itself sometime the teeth break that could be the clicking you hear I would check the fuse and if its ok I would remove the cover and check the teeth on the gear.
    also your battery voltage looks a bit low
    Apr 2013
    Aberdeenshire
    595
    Not sure what fuse as I have a 3.2 but if you google vw or audi v157 you will see issues of broken gears but I would check as much as possible before pulling it to bits as it could even just be dirty.
    found this its on a passat but I would think the fuse layout would be similar.
    2.0 gt tdi problem
    amit91987's Avatar
    Nov 2010
    South West London
    101
    Hi I have tried looking at the fuses but they look completely different to the layout in the owner's manual and of the link provided earlier. Here is a photo I took earlier.
  1. Help With Error Code
    By S3 Sly in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th June 2011, 23:09
  2. Help with error codes P1103, P0139 and P0411
    By royster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2007, 22:12
  3. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
  4. Help with Vag code?00561 - Mixture Adaption limit not reached - Interm
    By imported_ChrisCardiffA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2005, 09:44
  5. HELP WITH VAG CODE! O2 SENSOR?
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 12:22
