JMB RetrofitsSky Insurance
    Jun 2013
    326
    Brakes giving slight squeak on s3
    My brakes are giving a slights squeak under light braking and it only does it sometimes, the car hardly gets used maybe just needing to be taking out for a good run and give them a good use ?
    Veneeringman's Avatar
    Bazinga
    Aug 2010
    Back in the UK
    638
    I Had this on my 61 plate S3, only now and again as I was coming to standstill, took the front wheels off stripped down the caliper and applied Pagid brake lubricant to the rear of the pads, squeak went away.
    It was just easier than taking it back to Audi and listening to their BullS**t.
    2012 Misano Red RS3 / Bucket seats Heated front & Rear / Aluminium Styling Pack / Bose / RNS-E / Bluetooth / Mobile phone prep low / AMI / Reversing Sensors / LED number plate lights / Led interior light pack / VCDS / Cruise Control / Exclusive Inlays / Auto Lights & Wipers / 8.5J fronts / extended leather / Michelin Pilot super sport tyres / and a few other things
    Oct 2012
    243
    Might be a bit of corrosion on the discs, a few hard stops should clean them up. Failing that some copper slip behind the pads might resolve it. I think you can also buy anti squeal shims that may help.
    NME
    NME's Avatar
    Mar 2011
    Near the Muller Dairy!
    146
    Quote Originally Posted by S3_Mat View Post
    Yeah, apply some copper slip or similar product to the back of the brake pads as suggested.
    Bikers have been doing it for years to stop this noise!
  1. My S3 brakes do not stop squeaking!
    By eugegall in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2010, 11:03
  2. Vibration from Brakes and squeaking
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th November 2008, 19:52
  3. Squeaking brakes!!!!!!!!!!!
    By stevieyid in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2008, 23:26
  4. Recently upgraded brakes, slightly concerned
    By JGrant1285 in forum Handling
    Last Post: 21st September 2007, 19:19
  5. Squeaking brakes...
    By mdoyle69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2004, 13:21
