Volks AutosChris Nott
Results 1 to 12 of 12
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    (Broad Range Search Done) MFSW - Coding - Butons Wont functioning correctly :(
    Hi Folks
    I got the issue on the topic The button lights are working. Left scroll is not working, when I clicked left scroll it raises the volume. Mode is tuning radio stations, bluetooth button makes the same vice versa, left scroll is not working, clicked on left scroll is decreasing the volume. We tried a few codes. But the one here; I found it after we packed back everything and set up my old system with the old module. Is this the right code: 0004042 ? ? ? 0011422 for an A3 with MFSW ???
    '' The scroll wheels work which suggests the correct steering ECU is fitted, but it's certainly worth checking is the correct part number. Also check the steering wheel coding on module 16, (not 15 that's the airbag) with vagcom. Mine is coded 0004042 the important bits being -
    xxx4xxx - MFSW with radio, telephone & voice control, sounds like yours is set to 2 which is radio controls only
    xxxxx4x - In my case board computer & cruise control if you don't have cruise this should be a 1
    And also check the long coding for module 19 and look to see if these bits are set.
    Byte 02 Bit 0 Steering Wheel Electronics
    Byte 03 Bit 7 Telephone
    Good luck! ''
    You may find my modules part nmbers + my steering wheels part number + the picture of my concert. Car is 2006 year.
    My engine no: BLF 283 410
    Chasis No: WAUZZZ8P86A193324
    Cable: I have the right cable for sure. ( you may see it on the steering wheel picture anyway )
    The one I removed: Control Module ( Its not my hand )
    The new one: COntrol Module ( F is not written anywhere, is this the issue? )
    My steering wheel: 2006 S3
    Uploaded with ImageShack.us
    '' Wanna Trade Your Pre-facelift BRUSHED ALU interior trim with my Piano Black ones? '' PM me..
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    No idea? Anyone?
    Apr 2013
    Kettering, Northamptonshire
    172
    I have the same issue, the steering conrtols work but not as they should, The steering ecu needs to start with 8P0 and end in F.
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    So you mean it is the wrong module?
    and if YES, is it any harm on the other controls, electrics except not workin properly buttons?
    I can live with it by only reducing & rraising the volume, if there is not any other danger?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Perhaps the slip ring unit has an intermittent connection.
    Try putting the steering wheel on full lock, then try the buttons.
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Thanks mate
    BUT is the module wrong or correct?
    And what CODE should be coded?
    I'm not sure about these 2 first of all.
    Ash187's Avatar
    Audi Retrofitter
    Mar 2009
    6,407
    Wrong module! Simples
    A3 Sportback 2.0TDI
    Dark Headlining, Bose, Alcantara Leather, Interior Lights Pack
    MODS:
    S3 facelift,
    RS3 Grill, 19" RS6, TTRS FBMFSW, A5 S-Line Heated Seats, Bi-Xenons, Auto Lights & Wipers, Eibach Sportlines, Auto Folding & Dimming Dumbo Mirrors, S3 brakes, US Centre Console, Cruise, Pioneer HU, Reverse Camera, OEM Parking Sensors, LED Tail Lights, S3 Pedals, Tints, Carbon Trims.
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Sh$$t
    Who wants to buy my module? )
    Dec 2011
    MIDLANDS
    253
    Yes definitely wrong module, you need module ending in F for everything to work correctly. As for harming your electrics I wouldn't say so but I'm not totally sure. If you get F module you can fit cruise control as well.
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    KemiksiZ's Avatar
    Mar 2006
    TURKEY
    566
    Thanks Ash & Walto..
    What is my module for? Which car? I'm gonna sell it, paid 65 GBP :s
    ( I have cruise already )
    Apr 2013
    172
    Exactly what I said from the start!
    Dec 2011
    MIDLANDS
    253
    I thought the original module was the correct one for MFSW if you already got cruise? Maybe I'm wrong. I used module F to enable the cruise and steering wheel at the same time.
    There is a post on here somewhere detailing all the steering modules so Kemiksiz I'm sure if you do a search yo will find exactly what car your module is for.
  1. MFSW Coding
    By Brad. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2013, 18:45
  2. mfsw coding help
    By raz83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th August 2012, 21:22
  3. Help wanted! Flat battery, got it started and it wont run right!
    By jackpilk in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2012, 12:34
  4. MFSW Coding Help
    By Coling in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th November 2011, 18:28
  5. help please and yes, ive done a search
    By jpgibson in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2007, 21:53
