Volks AutosChris Nott
    Apr 2013
    15
    Audi Concert stuck on phone
    My audi concert is stuck on phone, left my car for about 20 minutes it was working fine then now all it says is "Phone" and it won't play any music. Help please, picture shown below:
    http://s15.postimg.org/sg6chrixn/image.jpg
    Jan 2012
    SW London
    751
    Sounds like the telephone mute is stuck on. When power is passed through the telephone mute wire, it cuts off all other audio and replaces it with the telephone audio. So if anyones done any dodgy wiring or its a retrofit or the wiring has been modified in any way then this could be why. If it hasnt then u've prob got a fault somewhere for it to keep doing this.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Mar 2012
    296
    Whip the stereo out (check you have the code just in case) there is a 10 way connector on the back - the one nearest the middle - pin 1 on that is the phone mute.
    BTW you didn't mention if you have a phone kit fitted......
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    pull the fuse and see if it resets
    scan with vcds for fault codes
    Apr 2013
    15
    Sorry for the lack of info but I don't have a phone connected and have not had a retrofit or any work done to it, I've had it (the car) about 6 months now and this is the first time it's happening it started working again yesterday but the same problem happened today. I might have to try removing it and checking the wires but I'm weary of this as I'm not too good with DIY
  1. Audi Concert CD Changer
    By Fozzie in forum In-Car Entertainment
    Last Post: 18th November 2011, 08:41
  2. Audi Concert Single Cd Player
    By iancooney in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2004, 18:57
  3. Audi Concert CD Changer
    By Fozzie in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2004, 09:03
  4. Audi Concert (Fiiting CD Changer)
    By JaceyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2004, 08:45
  5. Audi concert stereo
    By MarcA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 09:39
