AH FabricationsJMB Retrofits
    Jun 2013
    Bridlington
    144
    Something doesn't seem right...
    Audi A3 2004/2005 2.0 FSI Sport.
    Had a fuel leak a while ago so i took it back to the garage that i bought it from and they said that they sorted it and seemed ok but now the smell of petrol has come back so i want to replace the fuel rails and fittings.
    I have attached a photo of the rails, something doesn't seem right, there's paste all over the rails and there's a nut on both the these rails that go into the housing, i want to know are these nuts needed as i just thought the bolts should go straight through the pipe into the housing? (seems to me that they've done a bodge job)
    I'm buying the pipes and bolts from audi but when they sent me the order it came with no nuts? do i need them or not?
    27,083
    Well for me the fix is a very cowboy one unless you asked for as cheap as possible, looks like banjo fitment & they've basically sealed it with some crap.
    You should replace all the fixings, so including lines, bolts etc, but it may just be the fixings that need replacing as I can only surmise that's what is wrapped up from that pic.
    Jun 2013
    Bridlington
    144
    Yeah i've ordered all the parts but Audi didn't add the nuts on the order and said i don't need them which is strange because why are they on there now? do i need the nuts? or i'm guessing this is a cowboy fix and don't need the nuts
  1. NEW HEADLIGHT DOESN'T LOOK RIGHT !
    By ADC74 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st July 2011, 07:29
  2. New windscreen fitted, doesnt seem right!!
    By wibble111 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th November 2010, 22:22
  3. Milltek Doesn't look right
    By solaris in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th June 2010, 22:07
  4. Heating doesn't seem to be working correctly - advice?
    By gadgesxi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2010, 18:46
  5. EBC pad fitting - doesn't look right to me...
    By Marc1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th October 2009, 14:23
